Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
automatic tranny
This is not a complaint,just a curious question.Do any of the auto tranny folks find that the transmission shifts into---what seems to me---a higher than needed gear while you are going between 30--40 mph?.If that is what it does normally,then,thats what it does!.I presume it is a fuel saving measure programmed into the unit!.
TIA.
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Sep 2009
Yes, mine does.
I just keep it in D3 when driving in town. |
This is a common complaint and yes, it's normal. The "Cool" temp. gauge usually has to go out before it can shift into the next gear.
Tw200--excellent!
Thank you for da info!.
Chuck G. ................I presume you mean 3rd..the selector is kept too the left.The righthand position is 4th("overdrive").My Yaris only has 370ish miles on it and I've been experimenting with the tranny inregards to MPH etc.Not use to this vehicles rpm range yet...just seems to be laboring in 3rd when your only doing 35--40 mph?.Oh well,still a good little car!. |
#5 | |
#6 | |
Drives: 07 sedan Join Date: Mar 2010
Yes, the auto can be finicky especially coming out of left turns that go uphill. Right when you come out of the turn and need power it drops to 3. That's why I keep it in 2 til I want it in 3. |
Tw200--excellent!
continuing with this saga....do any of you use a scangaugeII?....can anyone advise the rpm's(approx) when the tranny is in 3rd and you are goin around town....30--40 mph?. TIA
Half a Bubble Off Plumb
I DON'T want mine to stay in a lower gear any longer than necessary! That wastes fuel. It'll downshift if I want to poke the pedal harder. I back off on the pedal to encourage earlier upshifts.
Mine stays stuck winding out when going 30 mph and stubbornly won't kick down for awhile... I'm always afraid of giving the car a little more gas 'cause the tranny doesn't sound happy at all.
#10 | |
I only downshift the auto to keep the DFCO engaged as long as possible. However, that is a problem with my Jeep due to the bigger tires. The OD kicks in at 45 MPH, which is early especially when going uphill. I simply shut it off or downshift by tapping the gas pedal when necessary. It is why all autos allow you to do so! Cheers! M2
Albino truck smasher
Drives: '07 Yaris LB Auto Join Date: Oct 2008
Depending on the throttle position, between 2000 and 2300rpm in 3rd. When cruising in "D" or overdrive gear at 40mph with constant acceleration, its around 1500 rpm. The Yaris shifts around 2000 - 2200 rpm on normal acceleration, 2600 - 3500 on WOT.
Huh? It'll wind up to about 6000 RPM on WOT. And 3500 or so on medium power.
Tw200--excellent!
Bingo SWISS
Not when shifting from 3rd to 4th/OD. I have tested it with a scangauge at WOT on a steep incline from 40-60mph multiple times and the highest the rpms ever went in D was 4900. Of course, keep it in 3 and it will bounce of the limiter all day long.
Tw200--excellent!
| manual vs. automatic | osmoq | Fuel Economy Forum | 82 | 01-26-2017 12:19 AM |
| Should I buy an automatic? | ktoyo | New YARIS Purchase Forum | 40 | 06-23-2010 02:09 PM |
| Used TOYOTA WS Automatic Tranny Fluid analysis : | Hershey | General Yaris / Vitz Discussion | 15 | 03-18-2010 06:29 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
| Automatic Choke Stuck | Rua | General Yaris / Vitz Discussion | 9 | 02-22-2007 06:57 PM |
