School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
So in my case, all theses below apply to me?
Part Numbers: Toyota OEM Cruise Control Stalk: 84632-34011 Toyota OEM Cruise Control Stalk Wire (Required to connect the stalk to the spiral cable, within the steering wheel): 84633-42030 Lower Steering wheel cover (with the hole already in it for the cruise stalk):45184-52130-B0 ECM repair terminal (Used to add the connection to pin 40 of connector A21 of the ECM on Yaris where "wiring to the ECM" is required - Quantity 1 required): 82998-24250 Spiral Connector Repair Terminals (Used to add the two pins to the steering column end of the spiral cable on Yaris where "Extra pins to the spiral cable" is required - Quantity 2 required): 82998-12870 Last edited by firemachine69; 07-13-2010 at 03:56 PM. Reason: Edited to reflect Scott's typo. ;) |
#2 | |
Correct - Except for the terminals for the Spiral cable connector - The correct part number is: 82998-12870. I was just double checking it and noticed that I had a typo in the FAQ. |
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
