Old 07-13-2010, 07:23 PM   #1
darkMINI
Drives: 08 hatch
Ok, thanks CTScott, is there a picture somewhere of this "spiral cable" you speak of? My stalk has a red and white wire coming out of it that end at a plastic connector that also has a short white wire with a female spade connector, but its not spiralled.
When I raped the poor Corolla of its cruise stalk I didn't see a spiral cable in the steering wheel.
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
darkMINI is offline   Reply With Quote
Old 07-13-2010, 08:51 PM   #2
The "spiral cable" or clockspring is the round plastic assembly that allows the steering wheel to turn without ripping out the airbag, horn, and cruise wires. When you pull the airbag, the connector where the cruise stalk (and horn) connects to is at the top. Here's a picture of mine with my cruise stalk installed:
If your Corolla connector is different than the Yaris one, then you will need to move the pins from the Corolla on to the existing cruise/horn connector.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
