Old 07-14-2010, 02:59 PM   #1
cfeng
Drives: Yaris 2010 Liftback
Jason, since you track your car often, you probably reset your ecu a lot. Do you know if the ecu adapts to settings over time?
Also, how greatly does your tune vary from the settings posted by power enterprises.
cfeng is offline   Reply With Quote
Old 07-14-2010, 03:07 PM   #2
Jason@SportsCar
We have a kill switch and shut off the power to the car whenever it is not in use. We have not seen any difference in output from when we first tuned it.
I did not tune it, we use a pro, so I have no idea how the settings compare. But imo, if you buy any type of tuning device and don't get a pro tune, on a dyno, you are not getting the full potential out of it - a tune needs to be calculated into the cost.
WTB: CAMCON CONTROLLER cruz-gsr Willing to Buy by private party 0 04-07-2010 06:53 PM
CAM TIMING jt258 Performance Modifications 21 11-12-2009 12:50 PM
Timing chain, sprockets, & cam position sensor problems? PetersRedYaris DIY / Maintenance / Service 8 01-04-2007 11:50 AM
