![]() ![]() ![]() ![]() Drives: 06 yaris 5-dr le man Join Date: Mar 2006
yes, what you said just makes loads of sense.
you (and everyone else on the road) have LESS reaction time when you are travelling faster, simply because your time between hitting or avoiding an object is lessened due to your speed. it can't be any more common sense than this, i dont' care if you have the reflexes of martin brodeur, the laws of physics apply to everyone on the planet (as far as i know). what i really hope is that i never have a run in with you pars, while you are driving fast with all of those distractions. this is the definition of dangerous driving, imo, and your arrogance probably adds to the problem. |
#2 | |
![]() ![]() ![]() Drives: 07 Yaris Liftback Join Date: Aug 2006
Personally, I like the slow poke who follow the rules, even when they're about to cut you off or run you off the road, at least they take their time, which give you time to compensate. I suppose that's the one of the biggest problem on N.A highway, we've got two type of driving habit sharing the highway. One more akin to the Europeans who have very high speed limits and other who like camping out on the highway in comfort and want to be isolated from the road as much as possible. Regarding arrogance on the road, 'been there done that' and already know how it can get you in trouble. Hopefully, you practice what you preach, having a narrow minded attitude while on the road can lead to disaster, even if you're the only on the road who's following the rules. |
![]() ![]() ![]() Drives: 07 5spd red Yaris HB 1.5L 16V Join Date: Oct 2006
I started this tread to find the answer to the question of Is it safe for the car to downshift muti gears at once to speed up the car as NEEDED, not about how everyone drives on the road, not about is it good or bad to drive slow, or fast, many posts have been off the topic, please everyone, stay with the topic, I WASN'T asking about how we should drive on the road.
Parallel Parking Pro
Whether the RPM's at 6000rpm on third gear, or 3000rpm in fifth doesn't matter as long as you are doing a sensible speed. Right?
Just remember to rev-match the sucka when you do drop it down the gear, ie, blip the throttle whilst you're in neutral when moving gears across the gate. Clutch replacement is troublesome and costly. But seriously, normally if where I'm caught in a situation where I'm in fifth gear when I'm really needing third, I'd drop it to fourth to see if it gives enough torque, before I'd drop it again. |
#5 | |
I see, thank you , thank you for the info another thing, doesnt matter what gear nor how many gears i drop, as long as i dont hit the red line im oaky right?? then i need to get an RPM gauge
#6 | |
Good thing the dashboard in front of you has acreage for mounting a big 11,000rpm-style rev counter without blocking anything important.
back on topic
In my old car (Civic Hatch) it had a tinny engine but huge gearing (at 4000rpms I'm doing 165km/hr). So, top gear acceleration was pathetic, but fuel economy was amazing (5L/100km in both city/hwy...the sohc engine had very good low rpm power). So, you'd think with the above setup, my car would be pigeon-hole into a mundane driver. Not so, cause there's this thing called double downshift and in the case of my old car, always put the car into the power-band (right rpm). So if you know how to work the shifter, you could get the best of both world, quick engine response or amazing fuel economy. But it ya don't like constantly rowing the shifter and downshifting, it could get cumbersome, to constantly have to downshift in order to dial-up some decent passing power (but in my case, all the downshifting was just plain fun). Unlike my old Civic, my new Yaris is more practically geared and makes good use of the engine broad mid-range power, without having to downshift. So, dropping 2 gears when you're already doing over 3000rpm (which is most of time) does not return a big enough pay-back to make it worth while. Granted, they'll be those times when loafing around at around 1k-2k rpm and need to get going in a hurry, in which case, double downshift would be ideal. What would be great! is if the Yaris had a bigger engine (TS's 1.8L) that could comfortably drive six fat gears. It might not be a drag-race setup, but it would make for a much more usable car that's great for low rpm cruising and have more hidden power on tap, if you wanted to work the shifter, when on the go. |
| Questions on pricing | littlecarlove | New YARIS Purchase Forum | 17 | 10-29-2006 07:53 PM |
| Questions, questions... | littlecarlove | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 10-21-2006 01:42 PM |
| More questions | Buckethead | DIY / Maintenance / Service | 1 | 08-01-2006 12:46 AM |
| Newbie questions about the 2007 Yaris | urabus | General Yaris / Vitz Discussion | 11 | 07-06-2006 11:32 AM |
| new owner.. have questions | chibianh | General Yaris / Vitz Discussion | 8 | 05-14-2006 11:44 AM |
