Old 12-21-2016, 09:08 PM   #1
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
Old 12-21-2016, 10:11 PM   #2
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Never really pushed either my Yaris or the previous Echo very hard. Found myself at 140km/90mph a few times with apparently still room left on the throttle.
Sent from my LG G2 with CM13 using Tapatalk
tarkus is offline   Reply With Quote
Old 12-22-2016, 04:35 AM   #3
VinceSA
Drives: 2007 Toyota Yaris T3
Without trying too hard, I have done 160 km/h in my 1.3 yaris (clock speed). I recon it still had a bit more to go - maybe 170ish
VinceSA is offline   Reply With Quote
Old 06-06-2017, 11:19 AM   #4
speed1
Drives: vitz rs
130mph-210kph on highway with my wife and full load at 7000rpm.. some n/a tuning.. just boring to try to faster.. engine revs 7800
speed1 is offline   Reply With Quote
Old 06-06-2017, 08:48 PM   #5
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Drives: 2006 Yaris 4 door 1.3l
I got up to 198 km/h (123 mp/h) today.
2SZ-FE 1.3l 87hp
5-Speed
I achieved that downhill on the autobahn and with a lot of patience.
When the car approaches 170 km/h (105 mp/h) it really climbs very slowly.
The car barely has enough power to top out in 4th gear on it's own.
You literally need to drive downhill to top out in fourth gear.
And it doesn't top out in 5th. 198 km/h at a little over 5000 rpm.
Rev limiter is at 6200 rpm.
Actually my goal was to get to 200 km/h (125 mp/h) but unfortunately another driver pulled in front of me to overtake a slower vehicle going "only" 150 km/h and i had to slow down a little. I bet the car can get up to 200 km/h if no one is interrupting your attempt. :D
Maybe lighter wheels and tires would to the job. I read an interesting article about the wheels and tires on the Bugatti Chiron. At 400 km/h the forces on the wheels and tires are incredible and i think they said that 3 tons of weight pull on every wheel at 400 km/h.
DiCaprio is offline   Reply With Quote
Old 06-07-2017, 05:51 AM   #6
speed1
Drives: vitz rs
2SZ-FE 1.3l 87hp
5-Speed
Hey man do u have 3.722 final gear? U made hi speed at low revs.. maybe 2nzfe 86hp engine uses so long final? So special cause my 1nzfe 106hp C56 tranny uses 4.312 final..
Old 06-07-2017, 10:50 AM   #7
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Actually i have no idea what my final drive ratio is
I tried to google it and they said it has a 4.06 final drive.
Old 06-06-2017, 08:52 PM   #8
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Oh by the way this engine is bullet proof. I drove 60 mins full throttle basically on the autobahn between Munich and Nuremburg and there was no sign of overheating.
Engine oil was constant at 110 Celsius ( 230 Fahrenheit ), which is pretty high, but unless the engine oil goes over 130 Celsius everything is ok, depending on what oil you have.
Cheap oil won't do the job at 130 Celsius.
Old 06-06-2017, 09:29 PM   #9
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
100 mph
Mods
C.A.I STRAIGHT PIPE (WEAPON R I TROTTLE CONTROL IS A MOST HAVE ) SOON COROLLA TROTTLE BODY PEFORMENCE CHIP WICH ONLY THING I NOTICE WAS A LIL BITE IF STRONGER 3 /4 GEAR AND MORE MPG . BUT REALLY THE WEAPON R I TROTTLE BODY CONTROL IS A MUST HAVE PLUS A FRONT FRONT V.W GTI SEAT
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 06-07-2017, 07:22 AM   #10
Yaris709
Drives: 07 yaris
176km/h or about 109mph? on straight smooth road. Didn't take as long as I thought it would to get there. That was max speed bounced off rev limiter and it slowed down
Yaris709 is offline   Reply With Quote
Old 06-07-2017, 12:42 PM   #11
ACKING_QC
Drives: 2018 VW TSi Stage1
With my OLD FULLSTOCK automatic 2000 Echo, I went to 182 Km/h...
I guess my manual Yaris can do the same if not better..
ACKING_QC is offline   Reply With Quote
Old 06-08-2017, 01:09 PM   #12
txusto
Drives: Yaris 2004
185 km/h with my D4D in plain road. No mods, this little bastard has power :D
txusto is offline   Reply With Quote
Old 06-09-2017, 01:39 AM   #13
zoidberg444
zoidberg444's Avatar
Is your D4D the 6 speed? I'd love one of those but I can get a couple used engines for mine cheaper than a turbo or an injector.
Sent from my SM-G930F using Tapatalk
UK to Nordkapp in a Yaris
Old 06-13-2017, 10:01 AM   #14
praivo
Drives: 2000 SCP10, 2001 NCP13
161 km/h or 100 mph, slightly uphill, while racing a random van (I won). 2000 1SZ-FE, no modifications other than using "premium" (98-octane) fuel.
praivo is offline   Reply With Quote
Old 06-13-2017, 12:06 PM   #15
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Right up and under the governor at around 113-114 mph. Had never gone much over 100 until just last Saturday while on my way to an appointment. Wasn't hard to do. I was trying to pass a group of moving road block idiots on the 10 West. When I looked over at the speedo, I was approaching 115, so I let off. Took no effort whatsoever.
On Instagram
On Wheelwell
Old 06-15-2017, 03:07 PM   #16
vivalaflam
Enthusiast
vivalaflam's Avatar
Drives: 07 Yaris HB 1.3 (EU)
I got up to 206km/h (GPS speed) in 5th gear at about 5500rpm if I remember correctly, happened during easter break here. Took a while to climb to 200+ after 185...
Engine is a 1.3L 92hp full stock, 2007 Yaris. Kept at 205-206 for a good 5 mins, did a 85km trip in 27 mins :P
(Serres - Thessaloniki, Greece)
Cheers, George.
vivalaflam is offline   Reply With Quote
Old 06-21-2017, 02:11 PM   #17
scott4banger
Drives: 2013 Yaris Le US
112 mph in a gen3 LE, optima battery and k&n air filter
scott4banger is offline   Reply With Quote
Old 10-15-2020, 01:14 PM   #18
Mister
Drives: Yaris T1
You guys are lucky. My 998cc Yaris gets beaten by granny scooters in drag races
Mister is offline   Reply With Quote
Stock Yaris as fast as stock 1982 Z28 Camaro/Trans Am!! 427chev General Yaris / Vitz Discussion 72 06-13-2012 03:20 PM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 06:06 PM
Im trying to figure out a easy way to make my yaris fast... help! nsracing Performance Modifications 61 04-11-2007 09:33 PM
