Old 04-01-2006, 11:40 PM   #1
YarisBueller
Administrator
YarisBueller's Avatar
Yaris stereo change PDFs
For the sedan I believe.. ?
File Type: pdf 036003-1002P_S0011_732ZF_T00BO_138_139.pdf (316.6 KB, 4453 views)
File Type: pdf 042003-1002W_S0017_732ZN_T00BS_41_49.pdf (991.8 KB, 3006 views)
YarisBueller is offline   Reply With Quote
Old 04-02-2006, 01:39 AM   #2
Sp33dY
www.OZTOYOTA.com
Drives: Toyota Echo
Excellent find! Wheres the rest of the workshop manual!?!?! :D
www.oztoyota.com - Australian Toyota ECHO and YARIS Club
Sp33dY is offline   Reply With Quote
Old 04-03-2006, 12:31 PM   #3
cburac
Drives: Toyota Yaris hatchba 5/dr 2006
I was wondering if you have the workshop manual for the rear spoiler instalation?
cheers
carlos b.
cburac is offline   Reply With Quote
Old 07-28-2006, 03:19 PM   #4
MacMaster761
Five-Star General
Drives: 07 Silver Streak Mica
Send a message via AIM to MacMaster761
found more helpful pdfs for everyone!
these are for the parts removal of the liftback
MacMaster761 is offline   Reply With Quote
Old 07-28-2006, 03:53 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Very nice....looks like a lot of clips that could get broken in the removal process I am wondering....
Old 09-13-2006, 04:55 PM   #6
ebowers83
ebowers83's Avatar
Drives: 2007 Yaris 4D Sedan
Those directions werent helpful at all. All they tell you is how to remove everything! I'm so confused!
ebowers83 is offline   Reply With Quote
Old 09-13-2006, 05:18 PM   #7
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
so far from everything I've removed (entire center console, and all the stereo/dash gauge console) all the clips are pretty sturdy and you'd have to really force them to go the wrong way before breaking them... atleast thats what my experiance has been.
just remember dont just rip stuff out, slowly but firmly pull out 1 clip at a time from bottom ==> top.
will work for parts
vodkalush is offline   Reply With Quote
Old 09-13-2006, 05:22 PM   #8
vodkalush
I drive a yarrrris
vodkalush's Avatar
well what else arent you sure about? As far as instation is concerned you will have to simply follow the directions that came with the new equitment
(or visit their website) , and then reverse the disassembly instructions to put it all back together.....
will work for parts
Old 11-05-2006, 01:48 AM   #9
atebit
Drives: 07 Yaris Sedan
This file (0370011.pdf) shows there are 3 connectors on the integrated radio, but only two on the non-integrated radio. Can someone tell me what each of these connectors are for? If I wanted to replace the integrated radio with an aftermarket HU, do I need a different/special harness because of this?
My guess (hope) is that the "third" connector is for the extra pair of speakers if you have the six-speaker system, and that I can just disreagard it if I only have 4 speakers....
atebit is offline   Reply With Quote
Old 11-05-2006, 09:51 AM   #10
jbll
Drives: Yaris HB 2007
I have the 6cd changer and there is 3 connectors on the back on the stock radio. When i changed my HU, i didn't pluged the third connector...
But I really don't know what the tird connector if for...
jbll is offline   Reply With Quote
Old 11-07-2006, 10:40 AM   #11
barryware
Originally Posted by jbll
But I really don't know what the third connector if for...
One connector is for power, acc power, ground, and front speakers. The second connector is for the rear speakers. The third connector you are referring to is for the Aux input. I don't have a CD changer but there are a total of 4 connectors on the stock radio. One mine, one had no connection and that is for the cd changer I believe.
I just replaced my stock radio with a deck that has an aux input in the back. That is how I know about the third connector. I had to connect that to the new deck for aux input.
barryware is offline   Reply With Quote
Old 07-16-2010, 04:08 PM   #12
rsoaramud
Drives: Yaris 2007 Sedan
hi all, just asking for yaris 2007, can somebody help me, is it possible to change the odometer same as 2010 model? my yaris 2007 only has the speedmeter i want to change it to 2010 model is it possible?
rsoaramud is offline   Reply With Quote
Old 05-21-2012, 04:33 AM   #13
syntax
syntax's Avatar
need to change the whole cluster, or install a separate tach...
Old 10-15-2022, 05:52 AM   #14
Navigator17
Drives: Toyota Yaris 2011 NCP90
Do we have a PDF that Explains Harness Wirings and what each Color Wire Does - I have a Toyota Yaris 2011 - NCP90R - and i want to understand which Wire Does what -
Reason i am saying this because i have installed a out of market Head unit but Speakers only work when i move my Car key beyond the End which is wiered or my Headunit doesnt turn off even when i have switched off the car - Here are the Wiring i have
Navigator17 is offline   Reply With Quote
is the yaris for me? sauruman New YARIS Purchase Forum 14 02-27-2006 09:27 PM
