Old 07-17-2010, 02:39 AM   #1
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by sito View Post
Thanks for the advice,tk-421...
Don't mention it.
With your 1NZ chip on the 1ZZ TB, did you experience any jerking (around 1300rpm) while you were driving?
The bigger TB will increase your overall throttle response. There's a bit on an adjustment required on your part (basically, one needs to be less hard on the pedal). Although to be honest, the throttle controller that I have installed makes that effect much more apparent.
Did you adjust your idling screw? How many turns did you adjust? Anti-clockwise?
I can't remember right now, but I believe it was more to the right (CW) than the left (CCW), but it really should depend on your particular installation. You can adjust it while the engine is on, but don't trust it too much... The ECU will also try to auto-adjust over the next few days. If you don't feel that it's perfect you can always try adjusting it further. Just be careful not to strip the screw!
Old 07-26-2010, 07:53 AM   #2
sito
Drives: Toyota
Don't mention it.
Thanks for the advice, tk-421....
sito is offline   Reply With Quote
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 05:20 PM
1ZZ-FE throttle body crxgames Items for Sale by private party 1 04-27-2009 05:19 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
DIY: Tricking ECU Throttle Body Relearning gwasabi DIY / Maintenance / Service 2 04-03-2009 07:02 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
