Crazy Girl (Kasey)
Drives: 09 Yaris 3D; 05 R6; 00civic si Join Date: Mar 2009
I have a 2009 3-door with 14,750miles (I'm taking her in this upcoming week for the 15K)
I have noticed in the past 2 weeks that when I have the wheel completely cranked over to the left I hear this loud "clunk" when I accelerate from a stop. (Like making tight U-turns or turning into a parking space). It will also happen in reverse when the wheel is cranked over. I tested it out and it's fine for tight right turns. Does this sound like it could be a CV boot issue? I'm going to try to investigate under the car again today to see if I can see anything torn, but haven't noticed anything when I checked a few days ago. ![]() Now, I noticed this clunking sound shortly after I was forced to straddle debris on the freeway from an accident. I think I straddled someone's tail light... So, I don't know if that was the culprit. I'll be bringing this up when I take it in for the tune up, but peace of mind is always nice when I commute 50+ miles several times a week. Any input is quite welcomed.
Could be a bad strut bearing or mount.
Drives: 07 sedan Join Date: Mar 2010
Don't turn your wheel all the way, especially while stopped. Its hard on the power steering and dangerous. I make U-turns on 2 lane(each way) roads and when I start moving the wheel is still straight. Also, if your wheel is turned while you are stopped, and you get rear ended, you get pushed into oncoming traffic.
If its only one direction it sounds like you tweaked your P/S rack from slamming it on U-turns. |
#4 | |
Crazy Girl (Kasey)
I was just giving an example. If I am turning into a parking space (or in the process of making a U-turn) it will make this sound. Even backing out of a tight spot where I have to turn the wheel to back up at an angle. It never has made this sound before. It's not like I changed my driving. |
Crazy Girl (Kasey)
This has happened to my husbands van (not the yaris) it ended up being a bad wheel bearing they just repacked it, now the other one is doing it (should have gotten both done at same time).
My Yaris was doing something similar like that on turns, I took it in and they found rocks in the brake rotor area.
http://www.midatlanticnostalgiaconvention.com |
#7 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
![]() lay off the chronic, dude |
#8 | |
should get professional diagnosis, or you may end up with one wheel busted and non-steerable if something is going bad |
![]() Drives: 2010 Yaris 5-dr auto Join Date: Jul 2010
Take it to service immediately! You are covered up to 35k miles.
#10 | |
Do you have anything useful to post, or just trolling, as is your MO these days. |
#11 | |
Crazy Girl (Kasey)
I used that terminology to let people know it's not just in simple turns... I don't have the wheel completely LOCKED over to the left, just more over than the typical 90 degree (or so) turn of the wheel, like for most turns at a street light. Here: Imagine.. you are waiting for a parking space on the left row. You are stopped so the car can pull out. Then you slowly pull up and turn LEFT (obviously you need to "crank" the wheel over more than you would for a turn at a light). As you begin to accelerate to move into the space.... "CLUNK". Maybe a diagram would help others...
Crazy Girl (Kasey)
Just scheduled my 15K for Wednesday. When talking to the service guy about this issue, he said that it could be a tire issue with how a tire is wearing. (They all look fine to me). I'll post up Wednesday with how things go.
#13 | |
Bob
Drives: Yaris and Scion XD 5 spd BSP Join Date: Dec 2009
Sounds like more like a loose nut upstairs, if you ask me...
#14 |
Crazy Girl (Kasey)
#15 |
Maybe your comprehension of the english language would help, your diagram did nothing for me. Completely cranked means only one thing. I smoke a lot of pot, but that has nothing to do with the situation. But, I must be really high because no matter how many times I re read my first post, I can't figure out how or why someone would take offense to it.
Did you figure out the problem yet? Or still clunking away and drawing pictures to help it out? |
#16 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
Could be a brake pad hanging up . We had a 1st generation MATRIX that did the clunk / click thing . Over time it went away with wear . Also some 1st generation VIBES ( MATRIX ) we test drove did the same thing . Hopefully just a pad , not a CV joint or other . The top of the strut can do that . The bushings . Have you hit any nasty potholes ? That'll do it . Let us know what it turns out to be and good luck .
#17 | ||
Crazy Girl (Kasey)
But how did this get from a thread about help with my car to about my comprehension of the English language? I said before that maybe I used the wrong terminology, but it seems like 99.9% of the people on this forum who read my post could understand what I was getting at. Maybe for the .1% (you) I needed to put it more simply and in stoner-speak. Look: How about not smoking weed and not jumping to conclusions and just try to be helpful instead? I wasn't offended by your post, more so confused as how you came to some conclusions like me having my wheel turned while not moving or "slamming" it on U-Turns. To me, saying I "slam" it in U-Turns is more or less a stab on my driving. Quote:
I would prefer that you not reply to any further posts in this thread as you are not helping any resolution as you do not even comprehend the situation. |
#18 | |
Crazy Girl (Kasey)
| Clicking Noise while Turning | Bella | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 06-12-2010 01:13 AM |
| 2006 Yaris clicking/clunking when turning | heistp | General Yaris / Vitz Discussion | 1 | 10-13-2009 09:48 AM |
| Humming noise when turning the steering wheel!! Help?? | mhkritzinger | DIY / Maintenance / Service | 7 | 09-28-2009 08:27 AM |
| Noise when turning | acuraphile | DIY / Maintenance / Service | 3 | 07-22-2009 02:25 PM |
| Side Turning Signal | ttufrosty | DIY / Maintenance / Service | 25 | 08-29-2007 01:33 PM |
