Old 07-20-2010, 11:45 AM   #1
Yarus Maximus
Drives: 2010 Yaris 5-dr auto
Putting automatic trans in neutral when going downhill?
There are stretches in my commute that are 1/2 mile downhill and rather steep. Is it safe to put the car in neutral, then back to drive at the bottom of the hill? I would like to save some fuel but do not want to harm the transmission.
Yarus Maximus is offline   Reply With Quote
Old 07-20-2010, 11:53 AM   #2
Astroman
Modded Moderator
Astroman's Avatar
It's not safe or good for your transmission, and you're actually not saving as much fuel as you would leaving it in gear. While in gear and going downhill DFCO kicks in, shutting off the injectors. The engine is still running, its just not getting fuel. When you put it in into neutral DFCO doesn't work so you still are using gas. I have an automatic with a scangauge II.
Old 07-20-2010, 11:59 AM   #3
127.0.0.1
above....totally depends on the speed, and steepness of the hill
some hills, dfco is more economical
some other hills, neutral is more economical
you really need a real-time mpg reading if you need to nail it down.
if in doubt, leave it in gear...it is 'overall' better for the car and mileage
neutral doesn't hurt the auto tranny, but kicking it back at improper rpm's
can stress the solenoids and clutches. and with no engine braking you may
just end up wearing the brakes faster
Old 07-20-2010, 12:27 PM   #4
Astroman
Modded Moderator
Astroman's Avatar
Yeah a Scangauge II or similar works best to know for sure. Where I live 95% of the hills work best fuel wise leaving it in gear.
Old 07-20-2010, 01:04 PM   #5
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
There's a part of my commute where I go downhill for 2 miles. If I start the hill at 60 it still stays in 60 while using DFCO. I don't have a scangauge but I figure I would get better gas mileage than driving slower up the hill and speeding down the hill.
KrazyDawg is offline   Reply With Quote
Should I buy an automatic? ktoyo New YARIS Purchase Forum 40 06-23-2010 03:09 PM
CLICK sound when putting Automatic transmission from D to P and vice versa Swallow General Yaris / Vitz Discussion 8 05-03-2010 08:25 PM
wanted a 08 yaris lb automatic trans working ecu unit pennyracer Willing to Buy by private party 0 08-28-2009 12:26 AM
WHo have an automatic trans. spec? boyz Performance Modifications 3 04-30-2007 10:51 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 11:57 PM
