![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
That amp can be had for $130, so you did buy those speakers for $70. For that $70 you could have bought some type R alpines.
Crutchfield, while excellent with customer service and stuff like that, is WAY overpriced. I am looking to buy that same amp for the speaker level inputs as I am leaving my factory HU in. Going to power (4) SPR-17c's. Then I will get a mono amp down the line to power a sub:) And could you clarify the 6x9 sub statement? Last I checked 6x9 speakers aren't subs. I am consfused. If you have 2 6x9's in the rear then you will want a more powerful amp than the one you bought. |
#2 | |
Subs i have are tang bang 6x9 here are the specs Specifications: *Power Handling: 90 watts RMS/170 watts max *VCdia: 1-1/2" *Impedance: 8 ohms *Re: 6.5 ohms *Frequency range: 35-350 Hz *Fs: 35 Hz *SPL: 87 dB 2.83V/1m *Vas: 1.34 cu.ft. *Qms: 6.05 *Qes: 0.37 *Qts: 0.35 *Xmax 7 mm *Dimensions: A: 6-1/2" x 9-1/4", C: 4-3/16". Where can you buy that amp for 130 shipped? |
| Help choosing sub | Duckywitbigfeetz | In Car Entertainment + Electronics (audio / video / alarm) | 40 | 03-31-2010 12:06 PM |
| An Interesting Discovery (Part Deux) | Stoln | Cosmetic Modifications (Exterior/Interior) | 11 | 03-25-2010 09:13 PM |
| Quick advice needed on unfinished amp install | GreenSpeed | In Car Entertainment + Electronics (audio / video / alarm) | 15 | 01-15-2009 11:03 PM |
| Connect mono amp. + subwoofer to stock HU? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 23 | 10-28-2008 10:01 PM |
