Old 07-20-2010, 10:51 PM   #1
djct_watt
Drives: 2010 NCP91 5spd
It would take more pressure tan any pump I know of can deliver. Think about when your tire hits a pothole, or even better a pavement drop. The g-force is enough to increase the PSI exponentially and rapidly, but tire blowouts are rare.
In general, this is true. Over-inflation increases your odds of a blowout when encountering rough terrain or a pothole. But an under-inflated tire is just as bad if not worse.
However, if you have damage to your tires, especially to the sidewall in the form of heavy curb damage, your tires will be significantly weaker, leaving the possibility of pop while pumping.
djct_watt is offline   Reply With Quote
Old 07-21-2010, 12:22 PM   #2
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
Some people have probably seen this link before. It's an article about officers using tire pressures rated for max sidewell.
http://www.officer.com/web/online/Editorial-and-Features/Driving-Under-Pressure/19$27281
KrazyDawg is offline   Reply With Quote
Old 07-21-2010, 09:43 PM   #3
djct_watt
Yeah, I agree with everything the article says. But it does not mention damaged tires. If a tire is already damaged, high PSI will stress those damage points, but you shouldn't be driving around on a damaged on sidewall anyway. But hey, I could be wrong as it is just based on my experience.
Old 07-23-2010, 02:04 PM   #4
1stToyota
1stToyota's Avatar
Their tires are most likely V, W, Y or Z rated, because they're concerned about high speeds, not long coasting.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Tire Pressure Monitor Sensors....? 09TRD Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-19-2008 09:25 PM
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 05:53 PM
2008 Yaris with Tire Pressure Sensors nsmitchell General Yaris / Vitz Discussion 2 08-23-2007 11:34 AM
FS: Stock 15" RE92 tire GabL Items for Sale by private party 9 07-02-2007 02:20 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
