If you mean just while driving then no, it'll take slightly more energy to speed up the heavier flywheel to cruise speed, but once there, it takes basically no extra energy to keep it going around at steady speed.
You get less engine braking with a heavier flywheel because the drag of the drivetrain is being acted on by the energy stored in the flywheel's spinning mass. Less spinning mass=less force counteracting the wheels=more engine braking.
Originally Posted by Galavoxx
Just thinking... a big flywheel will help increase gas mileage. If the engine keeps spinning with all that stored energy from the flywheel, it doesn't need as much gas to keep going. Probably why there's not much engine braking. :(
