Old 07-20-2010, 02:12 AM   #1
Mzsumwun
Drives: 2008 yaris
abnormal sounds
hey my name is nancy and i've had a 2008 4 door yaris for almost 2 years. after the last visit to the dealership for an oil change, i started hearing abnormal things from my car. Rattles sounds, and crackling sounds.
The rattle sound happens when i brake at a stop light, and the crackling sounds come from my engine... i'm not sure what's wrong... anyone else have this problem?
Mzsumwun is offline   Reply With Quote
Old 07-20-2010, 02:55 AM   #2
Lucas13
Drives: 07 Yaris LB
My car got some bad clunk when braking hard; I suggest you tell the dealer to check the torque on the sub frame bolts.
Lucas13 is offline   Reply With Quote
Old 07-22-2010, 12:00 PM   #3
NH3R717
Drives: Yaris 3dr Hatch, White
Mine 'clunks' on the right side while turning left also, I was thinking subframe as well.
NH3R717 is offline   Reply With Quote
Old 07-22-2010, 01:53 PM   #4
big lo
big lo's Avatar
Drives: 2007 VIOS
Nancy just take the car to the dealer and have them do a complete check on the vehicle and dont take no for an anwser, you vehicle is under a warranty. Remember you the purchaser and if theres a defect or any type of problem the need to follow up and correct the situation, good luck.
Old 07-22-2010, 05:07 PM   #5
Lucas13
Drives: 07 Yaris LB
My clunks came back, My yaris is just problems...
Old 07-22-2010, 08:33 PM   #6
salmonz
salmonz's Avatar
Drives: 07 Yaris Sedan
I get a clunk when I turn right in my driveway while braking too. 07 yaris.
salmonz is offline   Reply With Quote
Old 07-23-2010, 01:53 PM   #7
Lucas13
Drives: 07 Yaris LB
Thumbs down
I think we all have that problem, at this point I’m not sure is something loose, bad struts, sway bar links, or control arms, I’m concerned that this car is doing all that right know its only 58k I was planning to keep it for ten years or more but with all the stuff that is going on with my Yaris (Huge list of problems) I don’t think is going to hold for all that time. What happened with Toyota? Is maybe just the Yaris that turned like the tercel? Their quality is , I had better experience with a Daewoo that I drove for 120k until I totaled it, none of this happened to it, it turned out to be a very good car.
Old 07-23-2010, 02:24 PM   #8
swidd
Drives: Yaris HB
Meanwhile, in my hamster, 71,000 and no issues despite hauling heavy loads (obese ex-wife).
crackling, rattles, stop
New brakes/rotors - sounds like metal on metal rubbing salmonz DIY / Maintenance / Service 9 07-20-2010 09:46 PM
Weird Clicking Sounds Itsnhi DIY / Maintenance / Service 6 12-22-2009 07:30 PM
HELP! SOUNDS LIKE ROCK HITTING WINDSHIELD JetfireK General Yaris / Vitz Discussion 2 04-08-2009 01:10 AM
SC Sounds id3379 Forced Induction Forum 8 02-24-2009 05:13 AM
Bad sounds. sheraz2000 General Yaris / Vitz Discussion 18 02-23-2009 07:29 PM
