Old 07-28-2010, 12:49 PM   #1
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
in the pics
the goo in the pan is water contamination
the carbon on the cylinders looks pretty normal
I do not see much sludge. sludge looks like shredded burnt toast covered in oil,
...black carbony grit....not much of that anywhere in the pics
127.0.0.1 is offline   Reply With Quote
Old 07-28-2010, 12:53 PM   #2
Hershey
Originally Posted by 127.0.0.1 View Post
in the pics
a slow internal head gasket leak ?
Old 07-28-2010, 12:55 PM   #3
127.0.0.1
yeah that could do all that, plus the extra carbon deposits on the left hand cylinder where you said your oil leak is
Old 07-28-2010, 01:18 PM   #4
Hershey
Thanks . Didn't notice the extra deposits in that cylinder nearest to where our leaks are ( circled in red ) . Makes you think that this may be an issue for these cars . The '08 has had a bit of rough idle when stopped ( idling ) since we bought it . Leaking head gasket from the factory ?
Old 07-28-2010, 01:41 PM   #5
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Thanks . Didn't notice the extra deposits in that cylinder nearest to where our leaks are ( circleed in red ) . Makes you think that this may be an issue for these cars . The '08 has had a bit of rough idle when stopped ( idling ) since we bought it . Leaking head gasket from the factory ?
I don't think your leak is widespread issue. I have an 08 LB and run synthetic. No leaks. So yes this may be an issue with a certain number of cars or you just got unlucky.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
