CERTIFIED ASE/SUBARU TECH
You are absolutely correct about starting on synthetic too early,the engine requires the factory filled high detergent oil for break-in.I extensively reserched the sluge issue,and every source points back to my first post,...change your oil every time the maintenance minder light comes on.pay no attention to what anyone says regaurding changing your oil at 3000 or 5000 miles,as those are just industry standards...not Toyotas.The maintenance minder system caculates by its own milage interval.sludge is caused by water in the oil,it gets in there via condensation everytime you engine is shut down and the oil temp drops below 212 degrees farenheit.the longer the same oil is used the more water accumulates,this is while oil shoud be changed once a year even if the engine is never started.
#2 | |
close to 5000?
Toyota uses ENEOS NIPPON 0-20w or 0-50w syn in there cars. which is what they come from the factory.This comes from the window sticker from my 07 yaris.
eneos
#6 | |
. Do know they use a different oil filter from the factory for the break in period which is the 90915-10003 made by DENSO . Wonder if the factory installed 90915-10003 oil filter has better filtration than the TOYOTA ( Denso ) 90915-YZZF2 to catch metals , sealant residue , etc. ?
#7 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
read your owners/service manual...I just looked over mine, and it says it comes on "about" 4500 miles from the last reset.
#10 | |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
I believe synthetic oil has better "cleaning" characteristics than dino!...and,modern multi grade oils are detergent!. ![]() Just change your oil and filter.
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
