Old 07-29-2010, 03:21 PM   #1
Mad Goon
New To The Import Thing..
Mad Goon's Avatar
Drives: 07 Yaris 71 Comet 69 Maverick
Send a message via AIM to Mad Goon
Huh... I thought it was at a preset mileage... I changed my oil at 3,000 before the light came on and around 2000 more miles, BAM there goes the light..
What about the driver's habits? Frequent, short trips without allowing the car to reach operating temp could cause sludge buildup as well.. I know that a head gasket leak would answer a lot of this, but wouldn't the tops of those pistons also be clean with a slow amount of liquid(water) passing through(head gasket?) Carbon buildup there could also be answered with my statement as well...
This is pretty interesting though.. Who knows what the "lube technicians" did during those oil changes ... So many variables! x.x
Mad Goon is offline   Reply With Quote
Old 07-29-2010, 11:32 PM   #2
Hershey
If it's a very fine internal leak most moisture probably would get burned off ( evaporate ) . So , could take a long time for it to accumulate internally . The only thing to most likely detect it early would be with a U.O.A. ( Used Oil Analysis ) . We may have to go that route .
Old 07-30-2010, 08:57 AM   #3
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
to detect a headgasket leak, you do a compression test on the
cylinders and a pressure test on the cooling system.
and use a block tester on the coolant to detect exhaust gasses
uoa is overkill, don't need one
127.0.0.1 is offline   Reply With Quote
Old 08-01-2010, 10:57 PM   #4
Mad Goon
Mad Goon's Avatar
Thumbs up
Ah good point! Best of luck, would love to get to the bottom of this... Makes me a little wary of the old lady's car..
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
