Old 07-30-2010, 10:54 AM   #1
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Could you back up a bit and take a photo of it from a distance - where the wire is entering the fuel filler area? It's not the wire to open the filler door from inside the car is it?
Old 07-30-2010, 11:03 AM   #2
I was wondering that as well. The way that the end is fused onto it makes it look more like a mechanical cable than an electrical one.
Old 07-30-2010, 12:01 PM   #3
chrsfrm
Drives: Yaris 1.4 T Spirit
Thanx guys, the filler cover still opens & closes easily as usual so I do not think it is that. It was my first thought too.
chrsfrm is offline   Reply With Quote
Old 07-30-2010, 12:09 PM   #4
chrsfrm
Tried some more pics but to be honest they did not show up anything more than the others. It is a bit tight in teh filler area. When you see the wire in real life it still looks like a single electrical wire with a female connection. The only possible places it could connect would be on bare metal, on the tube clamp. Is there a static earth to the filler? Not sure why though as filler tube is plastic.
Old 07-30-2010, 12:58 PM   #5
I'm stumped, as there's no ground shown in the EWDs anyplace near there.
I just looked at the EPC to see if it showed a harness that for some reason the EWDs lack, but it didn't. Here's the 04 diesel's fuel fill as shown by the EPC:
Old 07-30-2010, 01:05 PM   #6
chrsfrm
Yes, I had seen that diagram, no sign of the wire. I may just have a rogue wire sitting there. I'll put a voltmeter on it see if it shows anything, or also for continuity. Thanks for taking the time to help. Regards, Chris.
Old 02-10-2011, 10:02 AM   #7
Madman1375
Drives: Yaris 5 dr 2007
Fuel filler door won't open inside lever won't pull up either any ideas?
Madman1375 is offline   Reply With Quote
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
