Old 07-30-2010, 01:05 PM   #1
chrsfrm
Drives: Yaris 1.4 T Spirit
Yes, I had seen that diagram, no sign of the wire. I may just have a rogue wire sitting there. I'll put a voltmeter on it see if it shows anything, or also for continuity. Thanks for taking the time to help. Regards, Chris.
chrsfrm is offline   Reply With Quote
Old 02-10-2011, 10:02 AM   #2
Madman1375
Drives: Yaris 5 dr 2007
Fuel filler door won't open inside lever won't pull up either any ideas?
Madman1375 is offline   Reply With Quote
Old 02-10-2011, 11:24 AM   #3
Vinceb
Drives: 2008 5 Speed Sedan
is it frozen? (in Nova Scotia, that can easily happen in winter)
if there is no tension whatsoever on the release, then it could be a broken cable, if there is tension, then it's probably just stuck.
Have somebody pull up on the release (or prop it up so it's fully extended) and then using a small flat head screwdriver try to pry the door open.
*** make sure you wrap the long part of the screwdriver in cloth or something soft so you don't destroy your paint and cover the end of it as well. don't pry too hard either***
hopefully it opens and you can either clean it, or replace it - be warned though it may not close again after opening it if it's a mechanical issue.
Vinceb is offline   Reply With Quote
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
