Old 07-30-2010, 04:11 PM   #1
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
If DFCO actually uses no gas, then if you are running your AC when you are coasting, you are not using any fuel so it can't cost any gas to run it.
The cost difference between running the AC and not running it is so small that you really want to be hot.
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 08-09-2010, 06:53 PM   #2
bkrownd
bkrownd's Avatar
Drives: 2010 Yaris "5-door"
Depends on the heat/humidity/sunshine in your area. Usually cracking a couple windows and running the fan at 2 is sufficient cooling for my climate.
Another thing you could time with DFCO is when to run the defogger, since it uses the AC.
bkrownd is offline   Reply With Quote
