![]() ![]() Drives: 2007 4dr Sedan Silver Streak Join Date: May 2010
If the fan is set on 4 then it bypasses the resistors, if it's set any lower then (other than 0) it uses the resistors to limit the speed. You could bypass the normal circuitry using a relay or something, in fact you probably should.
Here is a solar powered vent, you could drill a big hole in the roof and pop one of those in. It would be easier and the extra chrome would look pretty slick!
| ACRONYM thread | Shroomster | Off-topic / Other Cars / Everything else Discussions | 45 | 02-15-2025 10:30 PM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| Solar powered High Bright LED lights replacing the fog lights | alan1828 | Canada | 10 | 05-14-2010 12:34 AM |
