Old 08-03-2010, 10:53 AM   #1
henry33
Drives: yaris1.33
Turbo and 1.33 engine ?
Is it possible to somehow mount turbo charger on this engine ?
it has stock 100 hp but it will need some extra power
is there some other possibility how to increase a performance of this engine ?
thanks
henry33 is offline   Reply With Quote
Old 08-03-2010, 11:30 AM   #2
cdydjded
Drives: Yaris LB Turbo
Yes you can, almost any engine can be turbocharged. You would have to build a custom kit since there are no bolt on kits available at this time. BTW what year Yaris do you have?
Old 08-04-2010, 03:17 AM   #3
henry33
Drives: yaris1.33
Hi thanks for the answer I have 2010 model
Old 08-04-2010, 11:09 AM   #4
cdydjded
Is your engine code 2NZFE or 2SZFE?
Old 08-05-2010, 03:41 AM   #5
henry33
Drives: yaris1.33
honestly I do not know since I have this car for two weeks ;) I will find out and let you know
Old 08-05-2010, 04:01 AM   #6
he would have the newer engine 1NR-FE, 100hp out of a 1.3L engine is not bad to start with!
but yes, if you have enough money, time and/or skill, you can turbocharge pretty much anything...
Old 08-05-2010, 04:15 AM   #7
henry33
Drives: yaris1.33
eTiMaGo: yes it is the 1NR-FE and it is very good engine but could be better with some modifications ;) what are other options to increase the power I am looking for some additional 10-20 HP.
BTW: your yaris is beautiful ;)
Old 08-23-2010, 06:28 AM   #8
henry33
Drives: yaris1.33
Hi i was trying to find some part for this engine but it is almost impossible ?
what are the best tuners make for toyota ?
Old 08-23-2010, 08:02 AM   #9
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
The engine is still a taboo for us since it was only launched recently. Don't expect much help like ones who own a 1NZFE.
BTW If it's of year 2010 I consider it is still under guarantee so make sure you know that doing custom work on the car like a turbo you are loosing your right of having your guarantee.
My opinion is enjoy it to the full while still under guarantee or else sell it and buy a decent car with more hp if you like power wise cars.
Parmas is offline   Reply With Quote
Old 08-23-2010, 08:19 AM   #10
henry33
Drives: yaris1.33
Parmas yes I was thinking about the voiding the warranty but since there are no part I won't do anything :( by the end of the warranty I hope to see some parts for this engine ?
don't you have the information whether this engine is going to be sold in US ?
Old 08-25-2010, 12:48 PM   #11
yaris 2sz
www.yarisclub.gr
yaris 2sz's Avatar
Drives: yaris 1.3 2sz - 1.33 1nr
it's 1NR-FE
it's new engine. every piston is 150gr lighter from 2SZ.
intake designed from F1 racing team and the head with yamaha i think
my opinion... don't do it.
yaris 2sz is offline   Reply With Quote
Old 08-25-2010, 01:04 PM   #12
you can try matching Toyota part numbers from the 1NZ to see if any aftermarket parts like crank pulley, header, etc. are a match.
Old 08-27-2010, 05:22 AM   #13
henry33
Drives: yaris1.33
yes it should be the 1nr-fe engine. what do you think is the exhaust similar to other engines ? how much horse power will I get if I change to whole exhaust for some racing one ? will be there some problems with lambda sensors ?
thanks
Old 08-27-2010, 05:42 AM   #14
the problem is, nobody knows yet, so you can be the first one to find out
Yaris 1.33 K&N filter DOMAV General Yaris / Vitz Discussion 7 05-06-2010 11:18 AM
Yaris 09 1.33 tire pressure yannis-b General Yaris / Vitz Discussion 12 12-09-2009 07:12 PM
just purchased a Yaris 1.33 VVT SR zbuzz General Yaris / Vitz Discussion 1 06-14-2009 08:41 PM
