![]() Drives: sedan auto 2010 Join Date: Jul 2010
Lost key (transponder and remote lock/unlock)
hi!
I just bought a new yaris 2010 model and shit happens - lost the one set of key (one with 2 button remote and an immobiliser built in) can someone tell me if i can disable the lost key transponder without going to the dealer or replacing the immobiliser? i guess the remote lock/unlock is not too critical but just don't like the idea that my key is somewhere OUT THERE and it is coded to my car still. i read that i can program a new set of key myself by following the manual but not sure if i can delete out the code without the tester used by toyota. thanks everybody! |
#2 | |
To wipe out the lost one, you put the system in "re-write" mode. This erases all registered remotes. Then, you go into "add" mode and add your non-lost one back in. If you look at page 107 of the Door Lock section of the service manual (posted in a sticky in the DIY section), the instructions are there. |
Thanks Scott ..... now to actually do it and cross my fingers that it works (or my understanding of the manual is right!!)
![]() Drives: black yaris Join Date: Jul 2013
Hi I have a 1999 yaris I've lost the only key to the car. There are no buttons on the key. Can someone please suggest the cheapest way of getting a new key. Without having to contact dealers for quotes
Thanks |
Also is there a code on the door barrel or the ignition
| My cool fancy new switchblade key with remote =) | YarisSedan | Cosmetic Modifications (Exterior/Interior) | 14 | 05-14-2009 02:22 PM |
