AKA Samurai Racer
ah ok , so you still got the cats in. it seems you got most of the power from the header then. i was looking at replacing my middle box , but it didnt seem so restrictive. thats quite a bit more torque ! im looking to do the k&N air intake system soon. i have noticed a good increase with the system i did aswell , i have gone 57mm from the middle oem box to the back with a megan racing exhaust.
im quite interested in the header and how it is designed .. i have been told the OEM headers are pretty good , but you seem to have gotten great gains , so obviosly there is power to be made. I see DC sports also has a header for our motor. the reason i said use the greddy , is that we got our top unichip guy in cpt that worked on our clients cars from a FN2 type R and a S2000 for example , and the car still didnt run 100% , the greddy is easy to map , if the guys can do unichip , they should be able to do greddy. |
![]() ![]() Drives: Yaris TS 1,8L Join Date: Oct 2008
Hi there.
What header is that? One of these? http://www.dcsports.com/4into1headerstoyota.html Are you sure it's for 1.8? |
![]() Drives: Yaris 1.8 TS Join Date: Oct 2009
It is quite more powerful. I wanted more acceleration. But according to my dyno tests, I have got torque and power throughout the entire rpm range, take off is much quicker now and also top end!
It is not a DC Sports header. It was manufactured by Viper Exhaust (www.viperperformance.co.za) I also wanted to put a k&n filter but I decided not to, since it only gives you that extra 4kw at full throttle (accelerator completely down), the rest of the time, it will not perform as good as the normal intake system. I enquired about it when fitting my exhaust at the auto clinic next door, they told me they even had to remove it and put the standard intake system back on from one vehicle because the fuel consumption was very high and was not performing well at all. They suggested that I should modify the existing airbox and run a pipe from the airbox to the bottom of the grill (for cold air). |
#4 | |
AKA Samurai Racer
the problem with most guys , is that they replace the stock airbox on a car without shielding it from the engine heat. i had the K&N typhoon setup on my 1.3 yaris , when it idles under heavy traffic it does get a little heatsoaked , but as soon as you drive , its all good. the only reason the cars are heavy of fuel is because the drive after the sound the filter makes , so they drive harder to hear the roar of the filter , and use more fuel , also , if the guys are running a aftermarket ECU , it needs to be re-mapped to the correct air / fuel ratio's , modern stock ECU's should be able to sort out the most of that on the fly. but good one on the exhaust !! |
| UNICHIP, is it worth it for the Yaris?? | leasaunce | Australia | 26 | 01-13-2013 05:50 AM |
| Where to get Cruise Control Fitted | jodiem | Australia | 4 | 09-11-2010 12:55 AM |
| New Braided Teflon Brake lines fitted | 1NZYaris1 | Performance Modifications | 7 | 12-21-2009 04:18 PM |
| Interest in a unichip ecu tune ????? | blacksandiegovitz | Performance Modifications | 25 | 07-12-2009 12:46 PM |
