![]() Drives: 08 Black Liftback S Join Date: Jul 2010
Hello!
I have a question, I hope you all don't mind.... I have an 08 liftback, MT, without wiring. I've installed the buttons and the wiring to ground and ECM. I don't have a harness for the clutch switch, so I need to rig the switch to go into the fuse box in the engine bay. (If this is wrong please correct me) The clutch switch has two contacts, so I assume I run two wires off of those contacts into the fuse box. My question is which wire goes where? Looking at the picture on the top of the 4th page of the pdf, I'm not entirely sure. |
#2 | |
Correct on the clutch switch wiring. The clutch switch goes to the blue wire indicated below and the white wire, to pins to the right of the blue. |
#3 | |
So both wires from the clutch switch splice into the blue wire and the white wire is moved to the right of the blue? Last edited by Daren; 08-12-2010 at 10:13 PM. Reason: The internet has made me dumb. |
No, one wire from the clutch switch connects to the blue and the other connects to the white.
Thank you so much.
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
