Old 08-13-2010, 05:21 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
since you're convinced that the "plugs slowly loose a bit of performance" you might as well explain exactly how they "loose" it? either a spark plug fires, or it doesn't. it's not rocket science.
Old 08-13-2010, 08:40 PM   #2
RedRide
RedRide's Avatar
OK....So, plugs are good for the life of a an engine no matter how many miles that may be.?
It's a fact of life that all sparks are not created equal even with the same type of plug and the "qualty" of a spark will effect performamce to one extent or another.
Dyno tests bares this out.
You have some "learning" to do.
Old 08-13-2010, 08:42 PM   #3
ddongbap
Tamago, this fool is calling you out.
Burn him like a Turbo Supra beats a Ferrari.
Btw, red, your logic can be done in reverse. If a spark 'looses' it, you should be changing it every trip.
Old 08-14-2010, 07:17 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
so you're telling me that a spark has a quality? electricity jumps "slower" through the air the older the plug gets?
electricity (light as well) travels at 186,000 miles per second. the erosion of a plug, as already mentioned, does NOT affect the "quality" of the spark, it simply creates a further distance for the spark to travel. the farther the spark can travel, the more "bang" you get from each plug firing. in some cases this will yield a "better" burn of fuel. but again, this all goes back to the actual device that creates the high voltage electricity in the first place, the coils themselves. once the coil cannot create enough voltage to jump the eroded gap in the spark plug, the plug no longer fires consistently. but as the gap increases (up to the point of failure) the spark SIZE increases, meaning a plug actually gets MORE efficient at igniting fuel.. do you understand?
now, a fouled plug will have a shorter spark, simply because the electricity does not have to travel as far (due to carbon or other buildup) from the electrode. smaller spark (what you call quality) = less capability to ignite the fuel/air mixture inside the combustion chamber.
so, if iridium plugs are considered to be a 100,000mile plug, changing them at 50,000miles is pointless. have you ever actually pulled a denso IK22 out of your engine and looked at it? even a 100,000mile denso plug looks almost brand new, no visible signs of erosion (on a stock, non boosted engine).
quality of spark? c'mon dude.
Old 08-14-2010, 11:17 AM   #5
auxmike
auxmike's Avatar
Is that the part number and brand for the stock Yaris plugs then?
spark plugs phenoyz DIY / Maintenance / Service 48 01-18-2023 02:26 PM
Spark plugs for yaris RS 2zrfe engine candy_red Yaris TS Talk 3 11-16-2009 01:20 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-01-2009 11:50 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
