#1 | ||
Start another Oil Thread!
electricity (light as well) travels at 186,000 miles per second. the erosion of a plug, as already mentioned, does NOT affect the "quality" of the spark, it simply creates a further distance for the spark to travel. the farther the spark can travel, the more "bang" you get from each plug firing. in some cases this will yield a "better" burn of fuel. but again, this all goes back to the actual device that creates the high voltage electricity in the first place, the coils themselves. once the coil cannot create enough voltage to jump the eroded gap in the spark plug, the plug no longer fires consistently. but as the gap increases (up to the point of failure) the spark SIZE increases, meaning a plug actually gets MORE efficient at igniting fuel.. do you understand? now, a fouled plug will have a shorter spark, simply because the electricity does not have to travel as far (due to carbon or other buildup) from the electrode. smaller spark (what you call quality) = less capability to ignite the fuel/air mixture inside the combustion chamber. so, if iridium plugs are considered to be a 100,000mile plug, changing them at 50,000miles is pointless. have you ever actually pulled a denso IK22 out of your engine and looked at it? even a 100,000mile denso plug looks almost brand new, no visible signs of erosion (on a stock, non boosted engine). quality of spark? c'mon dude.
you nailed it sir.
Is that the part number and brand for the stock Yaris plugs then?
Never take eyes off opponent - Bruce Lee |
| spark plugs | phenoyz | DIY / Maintenance / Service | 48 | 01-18-2023 03:26 PM |
| Spark plugs for yaris RS 2zrfe engine | candy_red | Yaris TS Talk | 3 | 11-16-2009 02:20 PM |
| article on spark plugs and the fit | kngrsll | Performance Modifications | 4 | 08-02-2009 12:50 AM |
| did autolite spark plugs screw up coil or coils ?? | la_scanner | DIY / Maintenance / Service | 20 | 04-09-2009 03:07 PM |
| Upgraded Spark Plugs For Boost | whooppee777 | Forced Induction Forum | 9 | 02-14-2009 02:53 PM |
