Old 08-23-2010, 10:47 PM   #1
djct_watt
Drives: 2010 NCP91 5spd
http://science.howstuffworks.com/eng.../gas-pump5.htm
A good read.
You have 1 of two things happening:
1) You haven't put a good enough seal from the pump nozzle to the filler hole to create a pressure seal, not allowing the gas to build up to trigger the auto shut-off.
2) You have a leak somewhere in your tank or filler neck causing air to escape. Do you ever get a check engine light? A leak is possible, however unlikely, due to the sensitivity of auto shut-offs, and the massive leak necessary to render them ineffective. That and a fuel leak in your tank would drive your sensors crazy, giving you constant check engine lights.
djct_watt is offline   Reply With Quote
Old 08-24-2010, 09:14 AM   #2
rudolfoz
Drives: 08 Yaris Sedan AT
So how do I fix that?
rudolfoz is offline   Reply With Quote
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Had problems filling the gas / petrol tank? fidgell General Yaris / Vitz Discussion 6 08-27-2010 03:47 PM
Filling up using spare gas tank. Yarimoto Fuel Economy Forum 5 08-19-2009 04:29 PM
Don't overfill your gas tank! kimona General Yaris / Vitz Discussion 19 07-17-2007 01:15 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
