Old 08-23-2010, 11:02 PM   #1
cdydjded
Drives: Yaris LB Turbo
Originally Posted by coheed View Post
Well I'm wanting to do 10psi daily and bump it up for track days. On a stock motor with stock rods & pistons i would not suggest to run more than 8lbs maxThings I'm concerned about are:
1. Will I need to sleeve the block if going to 15psi on the track maybe once every 2 months (if that)? The factory sleeves are not the problem, the issue is the factory pistons & rods
2. Will the injectors you supply be enough for 10psi everyday? Apply above answers
3. Will I have to upgrade coils at that boost level? No
According to zage's website they got 190bhp at .5 bar (7ish psi), so I was wanting to shoot for a lil over 200 at 10psi daily. And you've probably posted this but I'm to lazy to search for it right now, what turbo and trim would this be using? I was thinking t28 or gt28 with 54-64 trim level, in that range.
The only reason I posted this in this thread is someone may want this info in the future and maybe other people have input on my questions.
If you want 200hp you will have to upgrade the pistons & rods on the 1NZ. My kit or any for that matter, on an 1NZ with upgraded pistons/rods & other supporting mods (fuel system & good tune) will make 225-250hp @ 10-15lbs.
cdydjded is offline   Reply With Quote
Old 08-24-2010, 01:17 AM   #2
coheed
Drives: 08 BB LB
I was deffinitely planning on replacing rods and pistons. I wouldnt turbo any motor at 10psi or above without replacing those.
Bolt on turbo kit for our yaris! aucorium Forced Induction Forum 57 02-02-2010 07:50 PM
Turbo on an Automatic Yaris S Sedan...? Dadombomb15 Performance Modifications 4 11-07-2009 02:04 AM
Turbo, Supercharged, NA Yaris 1/4 mile times??? hatchbackkid82 Forced Induction Forum 15 07-12-2007 03:58 AM
