Old 08-24-2010, 03:45 PM   #1
Yarisduder
Yarisduder's Avatar
Drives: 2007 4dr Sedan Silver Streak
He probably called it tridiode because he's French.
CT - Do you think cleaning the contacts as per your alternator break down post, or should I replace the voltage regulator assembly?
Also, do you happen to remember what size fittings I would need to replace them with stainless steel the way you did?
Yarisduder is offline   Reply With Quote
Old 08-24-2010, 03:50 PM   #2
For what's required to disassemble it, I'd probably pickup a regulator before tearing into it. Cleaning the contacts and preserving them is a good idea if it hasn't failed yet, but might not help if it already has. Unfortunately, I don't recall the screw sizes. I brought one of each type with me when I went to the HW store to pickup the stainless ones (they were all metric though).
