Old 08-24-2010, 04:32 PM   #1
rudolfoz
Drives: 08 Yaris Sedan AT
You didn't answer if the check engine light is on. And, if it's not, does it come on for a second when you initially turn the key?
Does the spilled fuel come out from around the pump nozzle (and spill down the side of the car) or does it spill out under the car?
The check engine is on only before starting the car. After that it goes off.
The fuel spills on the side of the car, not under the car
rudolfoz is offline   Reply With Quote
Old 08-24-2010, 04:45 PM   #2
If the vapor recovery system wasn't intact, then, (as mentioned above) the check engine light would be on.
So, it really points to the pumps not being setup properly. I would try a completely different gas station than you've used and ideally one with super modern looking pumps.
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Had problems filling the gas / petrol tank? fidgell General Yaris / Vitz Discussion 6 08-27-2010 03:47 PM
Filling up using spare gas tank. Yarimoto Fuel Economy Forum 5 08-19-2009 04:29 PM
Don't overfill your gas tank! kimona General Yaris / Vitz Discussion 19 07-17-2007 01:15 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
