Old 08-26-2010, 06:59 AM   #1
Originally Posted by Nebarnix View Post
Thanks!
That sure is a curious way to rig things up with three wires. Security to make it more difficult to hotwire? Hopefully the starter current isn't passing through those wires. I'd like to use these 30A power transistors I have laying around for the control.
You'll have to excuse me, I'm not much of a car person so some of these things which might be tribal knowledge escape me :)
Everything is low current at the switch. The starter, ignition and accessory wires all switch power to the coil of relays.
Old 08-27-2010, 08:41 PM   #2
Nebarnix
Nebarnix's Avatar
Thanks this is great. Interesting question though. How to sense when the key is turned on so that the lines can be dropped -- otherwise, you can't turn off the car because the remote start system is keeping them high!
It might be possible to interface with the speed sensor, break sensor, or cruise control clutch switch. If anyone can think of an easier way (maybe what the commercial units are using) it would be helpful!
Nebarnix is offline   Reply With Quote
Old 08-27-2010, 09:21 PM   #3
You can monitor the yellow wire on 2 pin connector on the side of the keyswitch assembly. It is the key sense wire and it goes to ground when the key is inserted.
Remote starters actually watch the brake to turn off. You have to turn the key to the one position before pressing the brake, otherwise the car shuts off. The brake is also the safety, as pressing it immediately kills the running car.
Old 08-28-2010, 01:23 PM   #4
Nebarnix
Nebarnix's Avatar
Sorry to keep bugging you and thank you for the information. Its perfect. I have one last question. On the DIY remote start wiring guide, the brake switching is listed as being on top of the brake pedal. Is that underneath the car or by the pedals?
Old 08-28-2010, 01:39 PM   #5
By the pedals. Right at the top of the brake pedal.
Old 09-09-2010, 04:37 PM   #6
Nebarnix
Nebarnix's Avatar
Ok, I see the wires. But there are 5 wires (not sure why, maybe tail lights?). Do you know which wire is connected to the switch and if it is a make/break or a pull high/low type of signal?
Thanks! Remote lock / unlock with the EZ-430 chronos is so freakin great, I even have it doing the double pulse to unlock all doors with one command. I feel like James Bond (it helps that the watch beeps as I activate the locks)
Old 09-09-2010, 04:52 PM   #7
On that connector, Green gets pulled to 12V when the pedal is pressed.
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
JDM GROUND WIRE VOLTAGE STABILIZER TOYOTA YARIS jamal1984 Performance Modifications 17 03-26-2007 01:01 PM
