![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
Pack a lunch when you go to the dealership. It maybe a long haul. Gotta just piss you off though.
UY |
#2 | |
![]() ![]() ![]() Drives: Yaris S Sedan color Flint Mica Join Date: Jan 2007
Yup.. I am not looking forward to taking my brand new car to the dealership with an electrical problem.. |
Problem solved after I went to the dealership.
I must have hit the switch cleaning the car. Apparently all our Yaris' all shut off the cluster lights when you run it all the way up. From the day I purchased the car it must have been on the full dimming area up and not past that little notch area. Even though our cars have a picture on the damn dial that shows the more up you roll the roller the brighter it gets and then a picture that shows the instrument panel lit up, must be wrong. I guess everyone can go try it and see. Turn on your head lights roll the roller up and watch the dimming console get brighter and brighter and then go past that little notch area and when you’re expecting to see the cluster panel be its brightest it cuts off. Some cars, when you get to that point and go past the notch it will turn on the dome light. And apparently what ever car they put that system in and the dome light comes on and it kicks off the cluster panel so you can see it when your driving at night with the dome light on. Is all i can figure. |
#4 | |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
also try another car at the dealers to see if it's the same.. |
Same here.. i keep mine at full lock (UP) position, and they are always on max bright, day or night.
#6 | |
I swear, I am almost convinced i saw it go out when i was backing up. But they had me almost convinced other wise when they brought that other car around.. I dont think i am loosing my mind.. Thanks |
#7 | |
I notice Chris07lb, has a hatch, maybe there different. |
#8 | |
o really?!!
others please check your car and post the results please.. |
![]() ![]() Drives: 07 YARIS Automatic/LiftBac/Red Join Date: Jan 2007
2007 Lift Back and mine is fine....................
sambo883 Southern ,NH
| Question about lights | kaymm | General Yaris / Vitz Discussion | 4 | 04-20-2020 09:10 PM |
| Smoke your own tail lights | ChinoCharles | Cosmetic Modifications (Exterior/Interior) | 9 | 01-15-2007 11:00 PM |
| Shift knobs with lights? | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 0 | 09-20-2006 04:09 PM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
| Fog lights for S sedans (US version) | paeko73 | General Yaris / Vitz Discussion | 11 | 07-02-2006 11:38 PM |
