Old 08-29-2010, 05:00 PM   #1
Kal-El
Kal-El's Avatar
Thanks CTscott.
I probably won't want to get into taking the dash apart myself.
How much do you think a dealer would charge - 1 or 2 hours of labor?
And are we talking about replacing a fairly cheap part or simply reconnecting a cable? I appreciate it.
Old 08-29-2010, 05:57 PM   #2
auxmike
auxmike's Avatar
Can you just reach in and move that piece by hand via the glovebox?
I always leave it on recirc.
Old 08-29-2010, 07:25 PM   #3
Thanks CTscott.
If memory serves me, the person form Canada was quoted 6 hours of labor for removing the dash and swapping the assembly.
Old 08-29-2010, 09:15 PM   #4
Kal-El
Kal-El's Avatar
That's outrageous. I don't know how I'll ever get it fixed if that's the case. 6 hours x $100 just for labor to fix a minor problem?
Old 08-29-2010, 09:25 PM   #5
Manley81bass
Manley81bass's Avatar
Drives: 07 Yaris liftback
The same thing happened to me. I just took the panel off and found that the cable had popped off the back. I reattached it and it works fine now. Quick, easy and free. Hopefully its as easy for you.
Manley81bass is offline   Reply With Quote
Old 08-29-2010, 10:10 PM   #6
Kal-El
Kal-El's Avatar
I'll definitely give it a try. Thanks
However, I've discovered worse news after going out tonight. The top left knob assembly in question doesn't light up now!! That's even more concerning and much more aggravating to go without. So if it's a mechanical cable that controls the switch, why is it affecting the backlight?
This sucks.
Old 08-30-2010, 07:07 AM   #7
This sucks.
There are two connections on the back of that knob assembly - The mechanical cable for the diverter and an electrical cable for the fan speed control. You definitely need to pop off the AC control panel and take a look at what came off and how.
Old 08-30-2010, 12:19 PM   #8
Kal-El
Kal-El's Avatar
Great news, I fixed it!!!
Pulled of the center panels and found that the assembly behind the switch had simply popped off. I re-attached and it's as good as new. All in 5 minutes. Wonder how much the dealer would have charged.
Thanks for your help guys.
I broke my fan switch... HELP *MAD DOG* DIY / Maintenance / Service 10 07-23-2009 09:47 AM
