Old 08-29-2010, 10:10 PM   #1
Kal-El
Kal-El's Avatar
Originally Posted by Manley81bass View Post
The same thing happened to me. I just took the panel off and found that the cable had popped off the back. I reattached it and it works fine now. Quick, easy and free. Hopefully its as easy for you.
I'll definitely give it a try. Thanks
However, I've discovered worse news after going out tonight. The top left knob assembly in question doesn't light up now!! That's even more concerning and much more aggravating to go without. So if it's a mechanical cable that controls the switch, why is it affecting the backlight?
This sucks.
Old 08-30-2010, 07:07 AM   #2
This sucks.
There are two connections on the back of that knob assembly - The mechanical cable for the diverter and an electrical cable for the fan speed control. You definitely need to pop off the AC control panel and take a look at what came off and how.
Old 08-30-2010, 12:19 PM   #3
Kal-El
Kal-El's Avatar
Great news, I fixed it!!!
Pulled of the center panels and found that the assembly behind the switch had simply popped off. I re-attached and it's as good as new. All in 5 minutes. Wonder how much the dealer would have charged.
Thanks for your help guys.
I broke my fan switch... HELP *MAD DOG* DIY / Maintenance / Service 10 07-23-2009 09:47 AM
