Old 08-29-2010, 11:11 PM   #1
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
How did you find the balance from side to side?
My Echo has nearly perfect weight distribution on the fronts, but the rears are 30 kg different. And the heavier side is the side with the muffler (but no fuel tank).
rob323 is offline   Reply With Quote
Old 08-30-2010, 12:54 PM   #2
Jason@SportsCar
When we first rolled it on the scales it was 100lbs light on the right rear, with near perfect front weights. I guess our 2.74lb Coast Fabrication muffler took too much weight off of that corner.
We have been able to improve the weights a bit, but we are trying to be really careful about overloading the left front - Road America is nearly all right hand turns, and we don't want to burn off the left front tire at the Runoffs.
Old 08-30-2010, 01:03 PM   #3
Jason@SportsCar
Hot off the presses... Just got a finished copy of the October issue with the Yaris intro. SCCA members should have the issue in 7-10 days.
Old 09-01-2010, 08:00 PM   #4
Jason@SportsCar
Just got the call from Toyota... New VVT cam gear installed, and we are fully operational. Back to the dyno for more power.
Old 09-02-2010, 10:32 PM   #5
rob323
New as in improved (adjustable?) or new as in standard replacement? In tother words, why the change?
Old 09-03-2010, 12:42 AM   #6
Jason@SportsCar
Standard replacement. The old one was frozen.
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 07:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 10:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 05:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 10:51 AM
