Old 08-31-2010, 09:34 PM   #1
Originally Posted by Skylinecar1982 View Post
Yeah I hooked up the brown for lock but no dice. But the bottom right wire (orange i believe) works but only for unlock.
And the factory keyless remote doesnt work when I start it just pulsing the wire manually
Thanks Mark
If the orange works for unlock, then the pink directly above the orange should work for lock.
I am not catching what you mean about the remote not working?
Old 08-31-2010, 09:39 PM   #2
Skylinecar1982
Drives: 2009 Yaris
Tried the pink too also no luck but will try again tomorrow.
I can take the green wire from the ultra start ( the wire that needs the negative pulse to start.) and I can manually ground the wire twice to make the remote start think it is getting a negative pulse. Then the device will start the car. Once the car is started through the device. The factory remote will not work anymore for the vehicle.
Thanks
Mark
Skylinecar1982 is offline   Reply With Quote
Old 08-31-2010, 09:53 PM   #3
Thanks
Mark
There are two pinks. Make sure that it's the large one on the end, not the small one in the middle.
Old 08-31-2010, 09:59 PM   #4
Skylinecar1982
Drives: 2009 Yaris
Yeah that is the one that I tried but it was late in the day and I will try again tomorrow.
thank you
Mark
Old 08-31-2010, 10:05 PM   #5
thank you
Mark
I just downloaded the manual for the 1155. They actually say to connect the pulse to start wire to the unlock rather than lock. They probably do that because of cars that have security that prevents them from starting unless the car was unlocked. That may be why your factory remote gets locked out after starting.
Old 08-31-2010, 10:50 PM   #6
Skylinecar1982
Drives: 2009 Yaris
Oh well I tried it on the lock and unlock wires on page 7 but nothing happened. But I did have it working with unlock using the thicker orange wire in the bottom right of the connector but , after it started the remote still wouldn't work. The doors where open but I wanted them to be closed so that I can start it and not have to watch it while it warms up.(security wise.)
Old 09-01-2010, 08:21 AM   #7
The 1155 has the option to relock after starting, so you could set it up to start on the double unlock pulse and then relock.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
