Old 09-04-2010, 10:51 PM   #1
sleey0
Drives: 2008 Yaris LB
One more for you kimona:
17x7 +38mm ET enkei ev5's.
Recommend the OEM 205/45 or 205/40 (or anything else)? I was told the 205/40's should be fine on less than 2" drop.
THANKS!
sleey0 is offline   Reply With Quote
Old 09-04-2010, 11:27 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
THANKS!
With 7's, ET38, I generally prefer 195mm rubber, but with 17's you don't have much choice but to run 205's.
I would prefer 205/45's with your 1.5" drop; however, with ET38-40, I'd probably run 205/40's... a tyre size I really don't like too much.
If at all possible, choose 7's with ET42 or greater; they just work better up front for a simple bolt and go application.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
