Old 01-01-2011, 02:26 PM   #1
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
sweet
Old 01-01-2011, 04:00 PM   #2
I have the wrong spring in my Tial MV-S wastegate
What is the wrong spring?
Old 01-02-2011, 02:51 AM   #3
^ I know that. You didn't answer my question.
I'm using a 10 psi spring and I can run up to 30 psi. So what spring are you using now, and what's wrong with it?
Old 01-02-2011, 01:44 PM   #4
^ I still don't understand why it's the "wrong" spring.
Old 01-02-2011, 04:23 PM   #5
xbgod
Drives: "Burning It Down GTX2860RS XB"
The gold spring was only allowing me to get to 5.8 psi before it would shut me down. So in order to make more PSI we took the waste gate out of the equation for now and set up the boost controller through the Greddy boost controller only and by-passed the wastegate all together. The problem with that is boost creep so I'm not pushing the envelpoe untill I change the spring sometime next week. Also had to reroute a couple of vacuum lines to do so.
Hope this explains it a little better.
XBG
xbgod is offline   Reply With Quote
Old 01-02-2011, 04:35 PM   #6
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Even if you have a lower wastegate spring, isn't the purpose of a boost controller to only allow the wastegate to crack open once it has reached the desired boost level? So even if you had the spring in with the boost controller attached, you would crack once the boost controller allows the air to flow into the wastegate regardless of whatever spring is in it?
I dunno if I am reading it wrong or am missing something, let me know
Old 01-02-2011, 06:56 PM   #7
This is not making sense, sorry.
The spring determines the minimum boost you can run, not the maximum.
The purpose of a boost controller is to run more than that (and get to it faster).
How did you control boost without a wastegate?
Old 01-02-2011, 09:44 PM   #8
xbgod
Yes I understand that too. Which is why I think Tial preinstalled that smaller spring. But my tuner has something else in mind. So off to what ever he deems necessary.
I don't care what he uses as long as I get to 380hp. Which at this point I know I can.
Turning off the VVTI with my system has worked out great. no issues what so ever.
XBG
Old 01-03-2011, 03:18 PM   #9
xbgod
Hope this clears up the spring issue:
The gold spring I had in the waste gate was a 4.8 and is only good for twice that amount of boost before it cant hold. (about 10psi)
The new combination is a Grey/gold which will hold upto 29psi. but the car must be able to make at a minimum 14.5lb of boost or you will never hold pressure.
Hope this helps peolpe understand a little better.
XBG
Old 01-03-2011, 04:07 PM   #10
It doesn't clear it up. Above the spring's rating, the boost controller keeps the wastegate shut until desired boost is reached.
I'll say no more on this, looking forward to your results which I'm sure will be good.
Old 01-03-2011, 07:25 PM   #11
xbgod
Thats the best I can do for ya Cali. I even talked to the Jake at Tial he said that gold spring would never work either for 28psi. Has to be the grey/ gold to make it happen.
On the other hand.......and this is for Parma..........
Shifter cable was burned right through. 200.00 for a new one. Wrapping the new one in DEI shield and having a aluminum shroud with a heat resistant material from DEI put on the other side of it to also block the heat.
You were right on with your S.W.A.G
XBG
Old 01-04-2011, 05:41 AM   #12
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
XBG
The trans cables are the only reason I kept the exhaust downpipe at 2.5". If I increased it to 3" I would surely burn a cable every month probably
The yaris engine bay is too compact to go extreme without issues like these...
Parmas is offline   Reply With Quote
Old 01-04-2011, 12:45 AM   #13
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The physical pressure inside the exhaust turbine is becoming greater than pressure of the spring before the desired boost level is being reached. So the pressure of the exhaust alone is enough to open the waste gate. No need to add vacuum pressure on the other side of the spring to open it, so no boost controller will ever be able to hold it closed if the there's more pressure inside the exhaust than spring pressure holding the gate shut.
So, desired boost pressure is a combination of exhaust pressure, spring pressure and vacuum pressure. The only one we have control over is vacuum.
Old 01-03-2011, 09:38 PM   #14
Tamago
Tamago's Avatar
Drives: UZJ100
i went through a set of cables after my turbo build too. it was a struggle. toyota put the cables dangerously close to the stock exhaust, and when you upgrade "go bigger" you immediately heat up your stock cables.
good luck Aras (asshole).
Old 01-03-2011, 10:07 PM   #15
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
looks like promising results so far. Hey remember i mentioned the wastegate spring a couple weeks ago.... hehe. I remember looking at your build pictures, one thing that is probably causing the creep is the fact your recirculating dump is kinda short and dumps at a perpindicular angle into the downpipe. The exhaust flow from the downpipe may be causing pressure in the dump therefore causing a reverse wastegating effect... boost creep. Worst case run an open dump. Having the wastegate opposite from turbo entry won't help either, but with a top mount log manifold i guess there is no place else for it. Your gonna run a lot of boost anyhow so creep wont really effect u at 30psi. With a proper wastegate spring, you should be able to hold 30psi all the way to redline with that turbo I would imagine.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 01-03-2011, 11:12 PM   #16
xbgod
Your so kind Tamago.....Thanks brother.
And I think your right about that.BlownXA
XBG
Old 01-04-2011, 12:04 AM   #17
ooh 30 psi... nom nom nom
Old 01-04-2011, 10:09 AM   #18
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Did your hood scoop help much in reducing underhood temps?
Want to build costom turbo kit. Need advice from boosted guys! pimp my yaris Forced Induction Forum 639 09-28-2013 11:26 AM
FS: 2005 Scion xA RS2.0 Turbo uberegg Cars for Sale by private party 40 04-03-2010 11:45 AM
Scion xd turbo PARIS Yaris TS Talk 22 02-26-2010 08:08 AM
Check out the new Scion iQ concept. In the States in 2011/2012 LA Yaris California 9 10-23-2009 08:11 PM
