Old 09-06-2010, 05:19 PM   #1
Skylinecar1982
Drives: 2009 Yaris
Yeah I found the two wires White and Red I disconnected the red and the wireless didn't work anymore nevermind when the key was in.
Do you know exactly what happens between the BCM and the Door Receiever within those two wires? I don't see any of the wires going directly to the door lock system. So the BCM has to do the work to cut it off.
So the issue is probably the key ecu telling the BCM that the key is in the ign. And to block the signal between the two may cause more issues then I have already.
Skylinecar1982 is offline   Reply With Quote
Old 09-06-2010, 06:32 PM   #2
Did you try the white separately as well? The reason I ask it that the two are listed as input an output, but it is not clear as to whether the in and out are relative to the body ECU or to the door control receiver.
The service manual doesn't detail the comm between the two, and since it is two wire, instead of one I believe that rather than being LIN bus, like a lot of the other subsystems are to their respective ECU, that it is simply a simple pulse signal in either direction. You could verify that with a voltmeter, by watching the white and red relative to body ground, while hitting the remote.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
