![]() Drives: 2010 yaris 3 door stick Join Date: Feb 2010
trans seal leaking
I have 2010 Yaris with 22,000 miles on it. Just in for inspection. Mechanic says left outer trans seal leaking. Should be covered under warranty. Is this a common problem for the Yaris? Is this a recall matter??
any help appreciated! thanks rick |
toyota
get a socket and tighten it is should close the gaps..i did the tightening on my celica 2x 70k clicks interval it got rid of the leaks.
#3 | |
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
Good luck! |
toyota
tranny and engine is covered 5 years or 100k..
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
One of you is speaking in Toyota America language and the other is Toyota Canada. lol
US is 5/60k for Powertrain. |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
Also depends on the dealer. I bought mine used and it came with balance of factory warranty and also 10 year or 100k powertrain warranty supplied by the Toyota dealer I bought from
toyota
60000 miles, not km.
![]() Drives: HB Toyota Yaris 07 VVT-i Join Date: Oct 2010
change tranny as soon as possible!!!!!!!!!! before it blows up!
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
Other than some forum chatter, there have been no consistent reports of problems with this vehicle and it is top rated for over all reliablity by several tracking sites for it's class. The vehicle is mass produced, there may be some failings for any number of reasons. In 50K miles of driving I've been lucky enough to have no problems.
![]() Drives: 09, 3dr, LB, Carmine Red Join Date: Oct 2010
Left side seal went out at 35,000 miles on my 2009.
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
My 2009 had a seal that was leaking (left axle seal). I cleaned it to confirm. 5,000 miles later, hasn't leaked again. If you see it leaking, take it in to get it done under warranty.
What to Mod Next?
Drives: 2008 3Dr HB, Bayou Blue Join Date: Oct 2009
My left axle seal on my manual tranny started leaking at 40k. Had it replaced under warranty. Now the car is back in the shop for a bad 3rd gear synchro. This is my first Toyota and I am not impressed with the tranny.
![]() Drives: '09 Yaris 3dr HB 5sp Join Date: Aug 2009
My drivers side axle seal has begun to leak on my 2009 hatchback (it has 110K miles on it). My dealer says a leaky drivers side axle seal is semi-common. $159.00 plus tax for parts and labor. Considering this is the ONLY hiccup I've had with this car I can't complain at all. I replaced the tires at 70K and I still have the original brakes.
"Never argue with an idiot. They drag you down to their level, then beat you with experience." |
Drives: 2008 Yaris SE Join Date: Dec 2012
driver's side axle seal
2008 manual transmission Sport edition, has 110k. Dealer informed me of a driver's side axle seal leaking. Took a look at it and it looks like a weep, but should I be worried? If I check my trans fluid regularly, is this a problem?
Not a weep isnt a problem.
And I wonder what everybody means by "Leak"? ![]() A real hairy chested gusher is for concern but as long as you maintain the level not a problem.
my driver side seal went shortly after they replaced the CV shaft due to the boot leaking.
other then that has been fine.
| SuperTech trans fluid (auto trans) | detroiter | DIY / Maintenance / Service | 11 | 08-20-2010 08:50 PM |
| Axle seals leaking caused by lowering ride height? | NH3R717 | DIY / Maintenance / Service | 2 | 07-22-2010 03:29 PM |
| Auto trans : Drive to Park + Handbrake : was not in park... | Maxh91 | General Yaris / Vitz Discussion | 7 | 06-11-2009 06:37 PM |
| Effects of too much trans fluid in the case? (auto trans) | detroiter | General Yaris / Vitz Discussion | 5 | 02-24-2009 11:08 PM |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
