Drives: "Burning It Down GTX2860RS XB" Join Date: Sep 2010
PETERPOOP.....was meaning to tell you, Your Yaris nicely done. Very clean and it sits well.
Here are some pics of the full stand-alone unit in my car. This is a Microtech set-up with Nology hot wires and Bosch Coil packs.
Remember people, just because you have nice parts and things that shine dosen't make it just a show car. It just means you have the ability to have those expensive parts as well as make it perform.
Here is a pic of a close-up of my motor showing the direct port Nitrous set up that I had welded in on the Weapon-R intake manifold. The blue tape is where the nitous feeds are going. Also all those interested in a clean nitrous set up, I've included a pic of the billet rail I'm using that holds all 3 noids. Makes for a clean install. |
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
Been using microtech for years. Orginally because it was my only real option 4 years ago. I tried the Greddy stuff back then and it sucked so bad I threw it in the garbage. Microtech is simple, it's in your face raw racing power, it's like MSD on steroids. no MAF sensor to worry about or other sensors to worry about. Microtech sees all my other sensors without issues and tunning is breeze. Also when seeking a tunner you need to also see what they tune with the best and that their not just guessing with your shit. I chose this system based on having a tunner that is certified in this system and a system that was reliable.
Yes there are newer and better systems out now and once I'm done if I'm not totally happy I will be going to Motec. This sysem will run me about 9,000.00 installed and tunned with all the features I would need. Motec is alacarte so every option cost you. I have the money to do this change but I want to see how things go this way first, before I spend another 9G. XBG |
Will Microtech interface with a knock sensor yet?
Good question and I'll be honest I don't even know if I have mine hooked up that way or not. I've gotten so good at listening for detonation that I back off when tunning. Not to mention I use Racing fuel when I'm tunning. Thats the other beauty of not having this as my daily driver is I can run race fuel and not worry about the expense.
I know some things have changed for the Microtech set-up so I'll find out for you about the knock sensor. Also keep in mind I may not be running the VVTI like most do. I'm going to use such a wild cam that I will more than likely not run VVTI. I've been running my set-up like VVT instead of a VVTI application as it stands right now. Remember I'm not using a MAF sensor. My set-up is race oriented. I don't care about fuel economy and I make up for the torque with my cams. These are two things that are usually related towards the VVTI which is responsable for both. XBG |
#9 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
I don't know Microtech but I am sure Haltech is better. It has about the same capabilities of a Motec engine managment. Currently Installed on my yaris although still needs tuning. Will post a dyno sheet next week probably. |
| Want to build costom turbo kit. Need advice from boosted guys! | pimp my yaris | Forced Induction Forum | 639 | 09-28-2013 11:26 AM |
| FS: 2005 Scion xA RS2.0 Turbo | uberegg | Cars for Sale by private party | 40 | 04-03-2010 11:45 AM |
| Scion xd turbo | PARIS | Yaris TS Talk | 22 | 02-26-2010 08:08 AM |
| Chevy Aveo RS: Turbo + good looks = build it! | Thirty-Nine | Off-topic / Other Cars / Everything else Discussions | 22 | 01-12-2010 12:36 PM |
| Check out the new Scion iQ concept. In the States in 2011/2012 | LA Yaris | California | 9 | 10-23-2009 08:11 PM |
