04-14-2010, 02:59 AM | #271 |
Bayou Blue Pearl.
Drives: Yaris 5D Liftback Full Options Join Date: Feb 2010
talnlnky: Thanks for the info. I will keep 85 in mind.
By the way: 100 Deg. C. is the boiling point of water, at 1 Atm pressure... That means at sea level. In a car's sealed engine and radiator, its under pressure. This keeps it from boiling at 100 Deg. C. Ofcourse its packing a lot more heat than water at 100 Deg. C. in an open container at sea level.
BOSCH 8000k HID Headlights, BOSCH 8000k HID Fog Lights. BOSCH Horn. 30% tint all round. 70% Tint mirror-finish tint on front wind shield. TRD Leather Shift Knob, Leather Steering Wheel, TRD Emblem. Height adjustable driver's seat is cool! and... That great armrest from ebay |
04-25-2010, 12:50 PM | #272 |
Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
filled up the 2010 automatic 3 door yesterday and the E.M. was right on the money with the calculated mileage . The C.M. and E.M. were 37.8 . The ECO-METER is set at 97 . This is a 1st for being exact . Have to see if next tank is the same .
07-20-2010, 06:57 PM | #273 |
I'll be getting mine in 2 days. I update my gas logs every 2 days if someone wants to track my data.
07-21-2010, 12:14 AM | #274 |
Nope . Reset to 98 . Reads a bit low , but at least I know it's doing a bit better than what the E.M. is showing .
07-21-2010, 03:59 AM | #275 |
Drives: 07 Yaris Turbo Join Date: May 2007
just a heads up, the Ecometer is $59.95 in my store with free shipping.
07-22-2010, 12:22 PM | #276 |
I'm looking into getting this cup holder mount so I can easily remove the Ecometer.
I found it for $11.84 on Walmart. http://www.walmart.com/ip/Bracketron...Mount/14248250 The other alternative was getting a flat mat. http://www.newegg.com/Product/Produc...82E16858999148 |
07-23-2010, 03:08 AM | #277 |
Drives: 06 Yaris HB CE Join Date: Aug 2009
can someone tell me where is the odc II port located? thanks
07-23-2010, 09:04 AM | #278 |
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
It is on the left side under the dash in front of the fusebox.... Next to the interior hood pop-up latch.
Cheers!
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS - (Click below to see Gaslog): Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
07-27-2010, 01:38 PM | #279 |
Office Depot sells the clear 3M Dual Lock strips if you need more for under $3. My initial install wore off the adhesive since I didn't apply it long enough and I remove the Ecometer from the dash on a regular basis. In my opinion, the included 3M Dual Lock works better than velcro. It "snaps" into place and looks more durable.
09-13-2010, 05:12 AM | #280 |
Drives: Decepticon - Ravage Join Date: Nov 2008
Bumping up my thread cuz its already filled with so much Ecometer info.
I have proven at least one so far that, the Ecometer is accurate to 0.002% (too high) on stock intake. On the AFE dry filter type 2 short ram it was consistenly ~10% too high AND using more fuel. On my latest fill up (10.119gal/last bar blinking), i got 34.2mpg Reading / 34.12mpg actual Compared with AFE ~35.6mpg Reading / 32.7mpg actual I never touched the eco-meter settings. so the only thing changed is the airbox replaced, one thing to note is i ran these two tests on stock size tires, the 185-60-15 flavor, reset ECU, cleaned MAF sensor with MAF cleaner spray, mix of Neutral/DFCO. Ironic enough I also drove much more spirited on the stock box, and dropped .4mpg cuz i idled to power my sub when i was doing some settings. I have no idea why the eco-meter reads higher value than actual with more air, which should equate to more fuel burned. So there you have it, stock air box/TIRES = perfect accuracy. Ill do another tank on stock box, to prove without a doubt. Tho it sucks to roll on steelies...
Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
09-13-2010, 11:36 AM | #281 | |
09-13-2010, 05:49 PM | #282 |
That's helps prove my point. Pretty sure at stock setting the eco meter would give you higher than actual. Plus I got to .002% 1/5th a percent. I'm gonna try to drive as conservative as I can this tank, then good bye steelies
01-10-2013, 10:19 AM | #283 |
[url=http://www.news77.co
Hello!
Good day!
I'm new here and came to this topic on www.yarisworld.com from yahoo search engine. I really think this topic on www.yarisworld.com is really interesting. I'm work on compared us payday loans related work and I have a blog which giving out info about loans For those, who asked me about payday loans reviews, I've obtained useful news about it. Now I don't have to worry about the unexpected bill getting paid. No personal questions, bad credit accepted, and the money is directly deposited into your checking account. I would suggest http://www.news77.com/payday-loans/ to anyone who needs quick, fast payday loans. There you can find the most trusted US compared lenders! I really hope that everyone here don't need some unexpected cash, but if any emergency appears, do not hesitate to use these services! thanks. |
01-10-2013, 10:07 PM | #284 | |
Drives: 2('14+'07)MT 3d ,wHandCrWndws! Join Date: May 2009
Thread Tools | |
Display Modes | |
