#91 | |
![]() Drives: 07 Yaris Join Date: Jun 2010
Any suggestions. Thanks! |
#92 | |
Based on the lights that came on, I would say at this point that your mechanic has the ECM pin in the wrong position. |
#93 |
You are correct. Cruise at last!
#94 |
My Pride & Joy...
Drives: 2010 Yaris 5 Door LB Join Date: Jul 2010
Easy Install
I have a 2010 5dr Liftback w/auto trans.
Per the Forum DIY, I used the following parts, ordered from ToyotaPartsZone.com: 84632-08021 Switch, Speed Control: Quantity 1 @ $78.89 84633-02020 Wire, Cruise Switch: Quantity 1 @ $27.93 45184-52130-B0 Cover, Steering Wheel: Quantity 1 @ $22.60 90159-50199 Screw, W/Washer: Quantity 2 @ $0.73 Installation took 20 minutes (taking my time). Works flawlessly. After installing, I found this switch on ebay for $19.99 plus $10 shipping. Can't tell if the wire is included or not. Last edited by daveprue; 09-15-2010 at 01:49 AM. |
#95 |
Cruise control on European Yaris
Hi everyone,
I want to hear the confirmation again. I read the thread and somewhere it is said that a European Yaris 09 cannot install cruise control using the method described above, is it true, and in that case, are there any other ways to install it myself without getting to dealer (who would ask for more than 500 Euro). Thanks in advance. |
#96 | |
Check out the link below. This Belgium based company makes an aftermarket CC for European Toyotas: http://www.el-pas.com/products.htm |
#97 |
Thanks, CTScott for your quick reply. I followed the link, and it is quite amazing to see such a product exists (donot know the price though). As there are differences between European models and American ones, regarding the mods to the car (to increase performance and stability), which one do you think is the most do-able ones? (rear-sway bar, SSK, strut bar...?). Thanks in advance.
#98 | |
#99 |
Regarding the SSK, how can I check if my Yaris 2009 is compatible?
#100 | |
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
I'll add... It's not the airbag you have to worry about (there are FAR too many fail-safes.) It's eletrocuting yourself with the electric horn spade connector. As me how I know...
#101 |
YIKES!!!!! The airbags don't actually have fail-safes. You just give them 12V and they go BOOOOOOOOM!!!!! The SRS system has fail-safes to prevent accidental deployment, but the airbags are just simple explosive charges. To dispose of an un-popped airbag, you simply apply 12V to make it pop (with the airbag contained in a stack of tires for safety).
#102 |
Well yes, but those connectors are hidden by rubber. Unless you're doing something worthy of a Darwin award, they will not magically receive receive twelve volts of power. (Unless your engine is running, coasting downhill, and happen to be stopped by a wall.
)Indirect heat doesn't set them off, either. Mechanic cut a stripped torch off the airbag in my Sunfire. We all gleefully awaited a BANG in the waiting room. Alas, only a bill for a half hour's worth of labour.
#103 |
+ 2006 CSM Scion tC
so i bought a 2007 scion xb steering wheel off ebay. won it in a bid for $9.99 with free shipping. came with the switch and the harness. just installed it. works like a charm.
2010 yaris sedan automatic with the power package so it was straight plug and play. $9.99!!!
#104 |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Sounds like a nice deal there the.family.car!
#105 |
+ 2006 CSM Scion tC
correction it was a 2008
thanks
automatic transmission w/ power package oem floor mats diy oem cruise control |
#106 |
Drives: 2010 yaris Join Date: Oct 2010
FYI for everyone according to my local Toyota parts dept those part numbers are for a 2008 yaris.... Also my dealer said there was no "kit" also. Guess it's time to show them this thread and school the boys!
#107 |
StickShift
Drives: 2010 Yaris HB Join Date: Nov 2010
Waiting for parts!
2010 3door in the driveway, Black w/ 5speed
power PKG, mats, Tinted back 3 windows putting CC on as soon as i get the parts! Great DYI it will make the install EASY!! saved me $$$!! |
#108 |
![]() ![]() Drives: 2010 Meteorite Liftback Join Date: Nov 2010
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
| How difficult is it to install the aftermarket cruise control kit? | grampi | Performance Modifications | 3 | 07-19-2007 08:06 AM |
