View Poll Results: Which Yaris do you have?
3-door Hatchback 646 46.51%
5-door Hatchback 434 31.25%
Sedan 320 23.04%
Multiple Choice Poll. Voters: 1389. You may not vote on this poll
Old 09-20-2010, 04:42 PM   #1
leinadeb
leinadeb's Avatar
Drives: 2001 Toyota Vitz Rs
Hi, i own a 2001 Vitz RS NCP10 model with the 2nz-fe engine (1.3l 16v). I know that in Japan and in the US as well they are called even Toyota Echo. Can anyone tell me if the Yaris/Vitz and the Echo are the same? Is the gearbox of the 1.5l echo the same as mine? I need to change the clutch and saw one on ebay which is not that expensive. It's an F1 Racing stage3 clutch kit. It says that it's only compatible with the 2000-2005 Echo 1.5. That's why i'd like to know if it fit's straight away my gearbox, and is the 1NZ-FE gearbox the same as the 2NZ-FE.
Cheers
leinadeb is offline   Reply With Quote
Old 09-20-2010, 05:09 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Cheers
it is not the same engine, i know that much. I doubt it is the same tranny, but even if it isn't it still could fit your car. You should e-mail the seller and ask.
i'm guessing they are the same transmission, it seems that the chassis code is all that is being listed, with the manual or auto transmission. I know some others here will be able to verify that better than I can.
Colin Chapman disciple
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
