The hole in the centre of the rim is the hub bore. The hub is on the vehicle. Aftermarket rims are manufactured with a very large hub bore in order to address fitment for a larger vehicle segment. Hub centric rings are then used to reduce this large bore to the exact hub diameter (54.1mm in our case) of the vehicle being mounted on. OEM rims are manufactured with an exact dimension hub bore. This is what makes it difficult to mate some rims to another vehicle even if offset and bolt pattern will work.
#2 | |
noob-toob
Drives: 2007 yaris 4dr sedan Join Date: Sep 2010
|| "it's a tough job, but somebody has got to do it" ||
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 09:44 AM |
| noob question.. | msfire671 | Cosmetic Modifications (Exterior/Interior) | 9 | 02-26-2010 11:58 PM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
| noob question | redduck | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 09-05-2007 06:34 PM |
| Question about Rims | MrJester | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 03-06-2007 10:16 PM |
