Old 09-22-2010, 02:46 PM   #1
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Originally Posted by nickstamat View Post
Hello guys, I need a little help here, because I did not come with an answer while searching.
Reference wheel fitment is this one (offered by TTE, so it is a perfect fit for the Yaris): Picture
Specs for the above pictured wheel are: 16x7" and ET45.
So, having in mind that tire size will definitely be 195/50/R16, which is the lowest offset that the wheel should have?
O.Z. Ultraleggera has ET37. Would ET37 be OK with the specified tire size?
The car is currently not lowered, but it might be lowered (no more than 1.2") in the future.
Thanks in advance!
No problems after I took the 10 mm spacers !
O.Z. Ultraleggera - 195/50/R16 - ET37
CLA 250, 4MATIC
Old 09-22-2010, 03:28 PM   #2
nickstamat
Yaris Lunatic!
Drives: Yaris 1.33L (1NR-FE) 3dr 6MT
derickveliz2, you have a very nice sedan
With ET37 wheels and 10mm spacers you actually got an effective ET27 (if I am not mistaken) and you had no problem with that? Sounds weird!
nickstamat is offline   Reply With Quote
Old 09-22-2010, 03:46 PM   #3
derickveliz2
I did have rubbing issues with 10mm spacers. without them no more rubbing.
I'm sorry I should have been more specific!
NO spacers = NO rubbing
D.
CLA 250, 4MATIC
Old 09-22-2010, 04:02 PM   #4
nickstamat
Yaris Lunatic!
D.
Ok, now I get it!
I also hope that the hatchback (which is what I have) has the same space under the fenders as the sedan!
Thanks for helping!
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
