Rwseattle
Drives: 2007 Toyota Yaris (BASE) Join Date: Dec 2006
I appriciate the tire size note but, If you read all the threads on tire size you will find that everyone has a different opion. I used the tires calc and with 16" wheels 205/45/16 is closest to the original size 175/65/14. Calc results "speedo reads 60mph, you are actually traveling 60.8mph 1.3%. With 205/50/16 the actuall speed is 62.9mph 4.9%. I believe you should stay under 3%. I will post a thread later and let you know how they preform. It shouldn't be a big deal. I will add springs and need to know if anyone installed springs with the tire size 205/45/16?
Try putting a GPS in your car to check your actual speed against your speedometer. I did and found I was going slower than my speedo says. It seems like all new cars say your going a little faster than you really are which means your racking up miles faster, and getting worst mileage, than you should be. If I get new tires/wheels I'll be going up 3-5% in diameter to set the speedo right.
My car: 70MPH=67 actual MPH |
Rwseattle
That's interesting. Thx.
Rwseattle
DF210 level?
One more question,
Would the DF210 lowering springs level the car nicely? Thx. Rwseattle |
#5 | |
![]() ![]() ![]() Drives: Yaris S Sedan color Flint Mica Join Date: Jan 2007
that dont mean your odom is wrong.. check that.
They may just have the speedometer calibrated a few mph off on the top end on purpose. Lots of times your dead on speed on the slower mph than the higher mph. They want you to think that you’re going that speed to help you. Kind of like your clock. You may have it set 5 mins fast so when that alarm clock goes off you actually have five mins more. Also I went to NC one time and the GPS said I was off route and actually I was on the exact road I was to be on per its directions. I switched lanes and it said I was going the right way. Switched lanes back it thought I was off route again. So even that GPS thing is not right sometimes. I figure it was the elevation and maybe the GPS was not updated that this is a 6 lane highway. |
#6 | |
#7 | |
Example: 70(speedometer)MPH=67(actual)MPH - 4.28% off This means at 30(speedo)MPH, 4.28% off is 28.71(actual)MPH 1.28 MPH is not noticable on a speedometer but is still there and hence the speedometer is still incorrect. This is why higher speeds are required to see speedometer dicrepincies. How does it help me to think I'm going to fast? |
#8 | |
1 and 2 Look at the pictures above, and you will see the amount of drop each kit will give, from your stock height. TDF121 - Front 1.6" / Rear 1.8" TNF121 - Front 1.1" / Rear 1.3" 3 The TRD Red Lowering Spring Set lowers the car 1.2” in both front and rear The Black Yaris at/near the bottom of the page. 4 Springtech springs 1.7 in drop F\R These are the 4 I can find right off the bat for now.. |
#9 | |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
With a 185/60/15 stock size a 205/50/16 is 1.4% slower and a 205/45/16 is 2.0% faster. I like the look of the 50 series better. It fills the wheelwell out more and makes the car appear lower with a more agressive stance. |
#10 | |||
I am no expert on any of this. I simply am trying to give a different perspective or idea for you to consider based on an error I found. Therefore proving there could be other types of errors. This is simply my thoughts other wise I would have put in some sources for everyone. It would be cool to have a stop watch set the cruise on 60mph on a leval hwy and see if you go exactly a mile in one min. i dont have a watch with seconds or stop watch to try it.
You have some good ideas Go4th.
The timer thing, I'll try it.I suppose it could be car manufacturers covering themselves. The downfall is, over-estimating speed means over-estimating miles per tank, which means mileage is poorer than it appears. It all a big conspiracy, the oil companies got a grip on the government, their feeding us a bunch of lies man! (Cars) |
Rwseattle
Added 16" with 205/45/16
Little bit more road noise, but not bad. See pic.
Rwseattle
Sorry pixz didn't attached correctly. I will post pictures later or check out the little pic under rwseattle.
| tanabe nf210 vs. TRD lowering springs?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 01-23-2012 11:00 PM |
| Lowering Springs - Questions ~ | jaspie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 01-10-2007 08:21 AM |
| TRD lowering springs' and/or shocks' Ride Quality?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 08-29-2006 12:42 PM |
| Will putting new lowering springs damage original shock absorbers in the long run? | Joel Leong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 06-07-2006 08:30 AM |
