#1 | |
![]() ![]() ![]() Drives: Yaris S Sedan color Flint Mica Join Date: Jan 2007
that dont mean your odom is wrong.. check that.
They may just have the speedometer calibrated a few mph off on the top end on purpose. Lots of times your dead on speed on the slower mph than the higher mph. They want you to think that you’re going that speed to help you. Kind of like your clock. You may have it set 5 mins fast so when that alarm clock goes off you actually have five mins more. Also I went to NC one time and the GPS said I was off route and actually I was on the exact road I was to be on per its directions. I switched lanes and it said I was going the right way. Switched lanes back it thought I was off route again. So even that GPS thing is not right sometimes. I figure it was the elevation and maybe the GPS was not updated that this is a 6 lane highway. |
#2 | |
#3 | |
Example: 70(speedometer)MPH=67(actual)MPH - 4.28% off This means at 30(speedo)MPH, 4.28% off is 28.71(actual)MPH 1.28 MPH is not noticable on a speedometer but is still there and hence the speedometer is still incorrect. This is why higher speeds are required to see speedometer dicrepincies. How does it help me to think I'm going to fast? |
| tanabe nf210 vs. TRD lowering springs?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 01-23-2012 11:00 PM |
| Lowering Springs - Questions ~ | jaspie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 01-10-2007 08:21 AM |
| TRD lowering springs' and/or shocks' Ride Quality?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 08-29-2006 12:42 PM |
| Will putting new lowering springs damage original shock absorbers in the long run? | Joel Leong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 06-07-2006 08:30 AM |
| Factory Lowering Springs + MAX Wheels? What are the options? | bigsky2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 05-24-2006 08:10 PM |
