Old 09-28-2010, 02:59 AM   #1
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Have you taken the control insert apart yet? You can put sound deadening on the edges of the panel to reduce the vibration.
I'd send you mine if you want. I have no problem re doing the inserts...although you'd be out your window controls until I got you mine.
― Thomas Paine
Old 09-29-2010, 10:00 AM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thanks man! don't worry I'm going to try and do some kickpanels. And I have a couple of questions:
Did you relocate the wires down there and extending a ground wire (both sides)?
How did you attached the speaker box (kick panel) in place? did you drilled into the fender and hold them mechanically?
Thanks
Derick
